Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Unread 16-09-2005, 21:19
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
easy way to find your robot weight.
if you are designing your robot in cad. it is a simple command of using Mass Proprieties. in autocad's case the command is massprop. the mass properties will tell you the volume of 3d objects all you have to do is take that volume and multiply it by how much that material weighs. like a cubic inch of aluminum weighs 0.0975 pounds roughly. this site http://www.allmeasures.com/Formulae/ has spreadsheets and tables that let you just let you plug in your numbers and you have your weight.
and thats my tip of the day.
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Image Discuss: 810 - Minotaur: Coming to a regional near you. CD47-Bot Robot Showcase 47 25-02-2003 16:19
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
