Go to Post You should take in to consideration who you are putting on to the field, not what. - NorviewsVeteran [more]
Unread 18-09-2005, 17:26
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Team Midnight Invention's robot TETRACIDE
a few things Alex left off. we are running a 24 volt system, the drives are pretty straight forward motor chained to wheels. It is a 2 WD system with chain to each wheel and ball transfers in the front. The pneumatic system is 3- 2inch bore cylinders running 250psi at each flipper. the pneumatics are powered by an on board 20 cu-ft nitrogen tank holding 2200psi. We are using a custom built pneumatic manifold for our cylinder control. The electronics in this system is a 2002 IFI Issac 32, with victor 883's to the motors and spikes controlling the pneumatics. the whole bot is solid welded construction and weights about 220 lbs.
i am working on putting all the build photos together and there will be a gallery soon.
Greg Needel│www.robogreg.com
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
