Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Unread 26-09-2005, 19:21
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: Team Fusion's T-Shirt Shooting Robot
Originally Posted by Andrew Blair
By the way, we are currently building our own t-shirst shooter!Yayyy!! And heres an idea we came up with: Our school uses really cheap, lightweight garbage bags in the small cans, and if the shirt(or other projectile of choice) is placed in the bag first, it slides much nicer in the pvc, as well as acting as a kind of sabot on launch. As far as the bags go, think of one of the plastic produce bags that are on the rolls and that you put your fruit in at the grocery store.
Here is a bit of advice, we found this out the hard way.
When pressing the shirt down the barrel during loading, you might feel a large static field/charge building up. If you can feel it, it's already beyond the point that it could cause damage to static sensitive devices such as the FET's in you Victors. So to reduce or dissipate this charge, add a grounding strap , cable or chain to the bot to ground it. We added a short length of chain to the bottom of the frame. It drags on the ground and makes a huge difference.
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
