Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
  #32   Spotlight this post!
Unread 26-09-2005, 21:58
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: Team Fusion's T-Shirt Shooting Robot
Originally Posted by Andrew Blair
wow, would have never thought of that problem... How exactly do you ground pvc though?
Our barrel is mounted to a metal section of our arm. We used a couple of large hose clamps, also metal. By looking carefully at the design of your bot, you should be able to determine if your attachment point is electrically connected to your chassis or frame. If it is, a chain or other conductor attached to the frame and dragging on the ground should suffice. Remember, high resistance in the path to ground isn't that big of a problem. For instance, an anti-static mat and wrist cord measure around 1 meg. ohm between the wrist-strap and the mat, and another 1 Meg to the ground clip. You don't need, nor necessarily want, a short to ground. Just make sure you have a conductive path from the barrel to ground that bypasses the electronics.
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
