Go to Post I've come to believe that the current alliance selection system is just like democracy. It's the worst system possible, aside from all the other ones. - DampRobot [more]
Unread 02-10-2005, 21:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: My wheel/leg design
From a more practical standpoint, if you make that entire shaft spin, you'll be putting a terribly large load on the bearings and shaft. Ball bearings are intended to support mostly radial loads. With your current design, the shaft bearing at the top would see a large thrust load, which would drastically shorten the bearing's life if you don't over-spec the bearing by a lot. Also, keep in mind that flexible shafts aren't going to transmit much torque.
pic: my more specific design mechanicalbrain Robot Showcase 6 29-06-2005 22:39
Team 862'sEDUbot Design competition GhostInTheShell Off-Season Events 4 26-06-2005 18:10
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
