Go to Post This thread is just as lethal as any design your own game thread. - Schnabel [more]
Unread 03-10-2005, 19:31
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: pic: My wheel/leg design
Originally Posted by Kevin Sevcik
It "walks" by whipping around that large gear the shaft bracket is attached to. Mind you, it'd walk better if the leg moved in and out as well as around or something similar. Perhaps instead of starting from scratch on both counts, you should find some simple leg joints that work for people and then figure out how to put wheels on them?
Yes thats exactly how it works. As to the retracting part. It would have to involve a mechanical function so i can keep the motors to a minimum. I want it to come around back so it can clear stairs and such objects. Finally, If I added wheels to the end of legs it would need to be some type of pulley system and then again I run into having more then two motors a leg.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
pic: my more specific design mechanicalbrain Robot Showcase 6 29-06-2005 22:39
Team 862'sEDUbot Design competition GhostInTheShell Off-Season Events 4 26-06-2005 18:10
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
