Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Unread 03-10-2005, 21:58
techtiger1's Avatar
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
Re: pic: 1" mecanum
Originally Posted by Tytus Gerrish
it's polycarbonate hubs delrin rolers and nylon screws. the hubs will be made by drilling the 7 dowell holes first. a block of aluminum is drilled with the same pattern and clamped to a cnc. you use dowell pins in the holes to mill with the head at a 45 when you dinish a pass you unclamp the hub pick it up rotate it and line it up with the pins clamp it again and make your next pass. the screws are a cheat they are just the shafts for the rolers basicaly and the heads have to be razorknifed off because they stick out too much.
Cool Tytus very cool. I see you have gotten away from the 2 part hub design this looks very new and improved. As always let me know if I can help.
Ttyl and good luck,
Drew
Team 1251 The TechTigers
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
