Go to Post ...many different kinds of students join our team. Some only have an interest in media, or others in cheering. What is important is that they are having fun while working in an engineering environment. - Bharat Nain [more]
Unread 10-05-2005, 10:52 PM
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
pic: Easy to make mecanum wheels
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 10-05-2005, 11:19 PM
Re: pic: Easy to make mecanum wheels
I was wondering when this would pop up. OK the idea is basically to bolt mecanum wheels to tread instead of making a wheel (some people only have wood shops ). I'm pretty sure that if you have two sets of tread on each side you can get the necessary sideways motion. My only concern is the side stress on the tread. I don't think rubber will work. It is going to need to be plated tread which Ive been searching for. If anyone with knowledge on either tread or mecanum wheels could help me it would be very welcomed.
Unread 10-05-2005, 11:25 PM
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Interesting idea, but I can tell you that the octagonal hub that 190's wheels bolted to was one of the easier parts of making the wheel. Just take a 3" square piece of aluminum and mill off the corners until you have 8 equal sides. You say only with a wood shop, but I don't know how you are going to make a roller support with only a wood shop. Casting the rollers and making the supports was the most difficult part.
I don't know how well non curved rollers would work either.
Unread 10-05-2005, 11:37 PM
Well i can make them curved but as you can tell from this picture that this is hardy a schematic. Actually i was thinking of taking a material (not sure what exactly but ive got a top five list) and using a belt sander. Ive actually seen teams make wheels just by sanding raw material! So yeah im hoping i can do this with a minimum on complexity.
Unread 10-05-2005, 11:42 PM
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
wouldn't those metal plates need to be bent? How would you keep it on the wheel? Wouldn't any force stretch the strip of fabric?
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 10-05-2005, 11:43 PM
FRC #0190
We tried that, but it wasnt too sucessful. We also tried taking urethane round stock and turning it on the lathe, but that didn't work too well either, atleast at the hardness we wanted. (We ended up with custom molds and pouring the rollers). If you went with a harder material, it might be possible.
It just seems like you are simplifying one of the easier parts of building them, and would require tons more rollers as well. I definitally see the same problem you do, with the strength of whatever you use as a tread actually holding it up.
Unread 10-05-2005, 11:52 PM
We can bend plates of metal. Also I'm not looking at rubber, I'm looking at plastic or thin metal tread. Even if it doesn't terribly simplify the process I think a tread has certain other benefits when it comes to stability and climbing stairs.
Unread 10-06-2005, 12:15 AM
FRC #0190
I'm no ME, but I doubt you can bend the size metal that you need to make those plates out of (and not have them bend) with a regular manual break. I'd guess theres some pretty big loads, as you are supporting a roller that is supporting a significant amount of the robot's weight on it.
Unread 10-06-2005, 12:20 AM
Well, I am becoming an ME so I'll take a shot at this one. We don't have a manual brake but I've bent 1/8" aluminum (and steel for that matter) quite nicely and fairly easily with a good mini-sledge and a vice. I think 1/8" would absolutely be sufficient for this, and you could probably get away with .090"
Unread 10-06-2005, 12:21 AM
well the weight is distributed evenly along the length of all the touching rollers on both treads on each side, but yeah they would be adequately thick.
Unread 10-06-2005, 12:36 AM
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Again, 190's wheels were slightly different than your treads, but our original aluminum supports bent with normal use (I don't remember the thickness, but they were at least 1/8") and we had to upgrade to steel.
Oh, and be careful bending metal on a vice. If you form a sharp corner, you will be losing a significant amount of strength.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 10-06-2005, 12:44 AM
So I take two pieces bent toward each other to make a tent type shape... Yeah you always protect whatever you stick in a vice! I use scrap Balsa wood (1/4") as a buffer of choice!
Unread 10-06-2005, 08:56 PM
EricH EricH is online now
I have three questions.
One, how are you going to keep from bouncing? You're driving along, and the roller edges hit the carpet coming around a 90 degree or so turn. Either you bounce, or you shatter the roller. Or maybe you shatter something else...
Two, how are you going to keep the rollers on? I mean, you can't just stick an axle through and say "stay" and have them stay on the axle. You need something hard on the outside, but how do you do that and not have to replace the whole tread?
Three, how much weight will this have? If it's too heavy, you might consider just wrapping the whole thing around a wheel for less weight.
Unread 10-06-2005, 09:06 PM
I dont think this would bounce more then a tread and i don't think it would necisarily break. Look at most robots, none have suspension yet they arent (always) falling apart. Since i haven't tested it I can't speak to the reality of this answer.
I was thinking of using faerie dust. Agian this is me using AutoCAD agian after two years. No i intend a central shaft or even two triangle mounting plates on either side with a central core.
Well.... this idea hasn't been built yet, but... take an average tread design and add 2-3 pounds.
Unread 10-06-2005, 09:28 PM
When you consider that normal treads don't really bounce, but mecanum wheels might in a spin, and you'd get full mecanum effect... but we'll see once you get a set built and tested. You've got 3 months...after which point they need to be in testing or you won't be able to convince your team to do it this year.
Oh, and for mounting the rollers, you may want to twist the supports so the tread will actually move over tread-suppporting rollers without tearing something. And for roller axles, just make sure you can get the rollers off when you want to but not when you don't want to.
pic: Powder make a difference CD47-Bot Robot Showcase 16 02-29-2004 04:13 AM
What do you use for wheels? Andrew Technical Discussion 36 01-08-2004 10:20 AM
who can we buy stuff from?!?! archiver 2001 7 06-23-2002 11:04 PM
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 04-22-2002 08:56 AM
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 01-29-2002 12:32 PM
