Re: pic: Easy to make mecanum wheels
Well, I am becoming an ME so I'll take a shot at this one. We don't have a manual brake but I've bent 1/8" aluminum (and steel for that matter) quite nicely and fairly easily with a good mini-sledge and a vice. I think 1/8" would absolutely be sufficient for this, and you could probably get away with .090"
Again, 190's wheels were slightly different than your treads, but our original aluminum supports bent with normal use (I don't remember the thickness, but they were at least 1/8") and we had to upgrade to steel.
Oh, and be careful bending metal on a vice. If you form a sharp corner, you will be losing a significant amount of strength. |
I have three questions.
One, how are you going to keep from bouncing? You're driving along, and the roller edges hit the carpet coming around a 90 degree or so turn. Either you bounce, or you shatter the roller. Or maybe you shatter something else... Two, how are you going to keep the rollers on? I mean, you can't just stick an axle through and say "stay" and have them stay on the axle. You need something hard on the outside, but how do you do that and not have to replace the whole tread? Three, how much weight will this have? If it's too heavy, you might consider just wrapping the whole thing around a wheel for less weight. |
I was thinking of using faerie dust. Agian this is me using AutoCAD agian after two years. No i intend a central shaft or even two triangle mounting plates on either side with a central core.Well.... this idea hasn't been built yet, but... take an average tread design and add 2-3 pounds. Last edited by mechanicalbrain : 10-06-2005 at 09:13 PM. |
Oh, and for mounting the rollers, you may want to twist the supports so the tread will actually move over tread-suppporting rollers without tearing something. And for roller axles, just make sure you can get the rollers off when you want to but not when you don't want to. |
Also I have no intent on using anything but a hard (probably plastic) jointed tread. Until i find a place that can supply me with adequate tread this will not become anything more than a prototype (I can get some small tread for hobby robots but thats it so far) |
| pic: Powder make a difference | CD47-Bot | Robot Showcase | 16 | 02-29-2004 04:13 AM |
| What do you use for wheels? | Andrew | Technical Discussion | 36 | 01-08-2004 10:20 AM |
| who can we buy stuff from?!?! | archiver | 2001 | 7 | 06-23-2002 11:04 PM |
| (CURIE) Let's make this Easy for all of us. [scouting] | 157#1Driver | Championship Event | 13 | 04-22-2002 08:56 AM |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 01-29-2002 12:32 PM |
