Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
Unread 07-10-2005, 09:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: My wheel/leg design
Originally Posted by mechanicalbrain
Yes thats exactly how it works. As to the retracting part. It would have to involve a mechanical function so i can keep the motors to a minimum. I want it to come around back so it can clear stairs and such objects. Finally, If I added wheels to the end of legs it would need to be some type of pulley system and then again I run into having more then two motors a leg.
Finally getting around to answering this... You could obviate the need for tons of extra motors, pulleys, chains, flexible shafts, etc by going with a large, well designed leg, and then putting a motor/gear case/wheel assembly on the end of it. Using FIRST parts, it'd be some sort of sturdy leg system with a Nothin'-But-Dewalts motor assembly attached to a wheel at the end of the leg. There are trade-offs, obviously. This makes your leg much heavier. But on the plus side, electricity is an awful lot easier to bend around corners than mechanical rotation.
pic: my more specific design mechanicalbrain Robot Showcase 6 29-06-2005 22:39
Team 862'sEDUbot Design competition GhostInTheShell Off-Season Events 4 26-06-2005 18:10
pic: 1305 Frame design with trannies CD47-Bot Robot Showcase 19 25-09-2004 01:13
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
