Go to Post In my opinion, leaders do not need to be picked. They naturally emerge as time goes on and as more opportunities are presented to them. - Alex Golec [more]
Unread 12-10-2005, 21:22
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: Beginnings of a gokart
Heres one important thing about your setup: i think those front wheels you have are the same ones we use on our go-cart, and they have a nasty habit of having the wheel separating from the hub. The small welds that hold the hub to the spoke portion break quite easily, but the wheel will not completley fall off. What'll happen is you'll not notice and end up rounding out the hole in the spoke portion, effectively creating a very nice piece of junk.
What you need to do is just remove the tire from the wheels and put some larger weld tacks on the hub. If you're careful you won't have to take the bearings out of the wheel, because that is a real #@!*. Avoid doing it at all costs.
Great idea! Try making it autonomous! Thats our little project, though it has been pushed to the side lately....
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
