Go to Post Someone once said, "I know what finished is, and I know what a robot is, but what is this finished robot you speak of?" - EricH [more]
Unread 13-10-2005, 00:22
Re: pic: Beginnings of a gokart
Thanks for the pics. I don't think you call that rack and pinion steering because there is no rack, and there is no pinion, but the pictured setup is the type of steering I plan to have.
How many HP is your engine?
The frame setup and wheel positioning on yours is interesting. It looks like you have your legs going over the tie rods. I might consider that. I was thinking of having the tie rods at the very front of the gokart and having the pitman arm and spindles pointing the other way and then having my pedals aft of the tie rods.
I'll have to sit on the ground and do some imagining to see what will work best for me.
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
