Re: pic: Beginnings of a gokart
one wheel drive could make it drive to one side or the other and the threads shouldn't make a big deal of trouble but i haven't tried it so i don't know you may be able to turn down the threads on a lathe and put some tubing over it the same OD as the ID of the bearings cut the tubing in half and weld it on the missing threads but that is a little too much work for what you probably want to do
or you could fill the threads with weld and grind it down to fit
[center]Our robot's name is HOMER, it stands for Human Operated Mechanicaly Engineered Robot
Our team name is Double Duece 22
If all else fails... blame the PROGRAMER
