Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 01-11-2005, 21:56
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: pic: Lego Robot for a F.I.R.S.T.-ish Game
i highly reccomend shortening your wheelbase or widening the track or using less grippy tires. you would have trouble turning iwth that setup. and i highly reccomend you learning how to use "Reinforcements" to make a stronger. more reliable robot with less weight. beam on beam on plate only works for so long.
and as for max amps from a rcx, do keep in mind its possible to use battery boxes and use an rcx to change the switches. doesnt drain the rcx batteries as fast either. have fun!
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
Online Game and Robot Quiz Metalhugginman General Forum 11 13-02-2004 14:21
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
