Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Unread 08-11-2005, 00:59
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
Re: pic: Inventor Fun
Originally Posted by RogerR
i think this is a pretty cool design; i like the use of the rods as structural members. what material thickness are you using, and why'd you choose to go with this option?
also, i notice that the rods on the sides don't run the length of the chassis, and i'm not sure how thick the base plate is; are there any concerns about the frame flexing (especially in the center)? or are you counting on support from the added superstructure that'll (probably) come with an end effect?
The rods are 3/8" Stainless Steel. The base plate is 1/4" Alum. The superstructure will add some support. I chose to use rods to get away from the "Box", and try something new.
-Rod-
Team 662
Colorado Springs, CO
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
