Go to Post Data is never ugly. It is only how you use it that can be. - Ed Law [more]
Unread 08-11-2005, 11:26
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: The Beginings of a Vex-Legal Space Elevator
After recieving a bunch of alpha-prototype parts from VexLabs/IFI for testing and feedback, I thought that I would create something cool. So out with my old single stage elevator on my Vex robot, and in with a multi-stage elevator using the new pieces. Right now it is only two-stage elevator with a maximum extended height of 55 1/2 inches. The elevator works very well so I may increase it to a three-stage elevator.
Also, the center of gravity is still so low on that robot, that even with a tetra on it almost five feet off the ground, it still won't tip over - even when going from full forward to full reverse immediately.
EDIT: Actually, I was three PWM cables short until I my father found one in the bottom of his laptop case. So the limit switches on the arm are useless, because three-foot PWM cables I used are about two-feet too short now.
Here are some more pictures I took outside this morning:
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-11-2005, 11:30
can i just say WOW
that's totally awesome!!! looking really great...
how fast does it take to extend up without the tetra on board?
Unread 08-11-2005, 11:53
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Rather than FRC robots using your Vex field, soon your Vex robot is gonna be using the FRC field.
Keep up the great work, Art.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 08-11-2005, 11:58
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
the channel pieces in the lift itself. will they be available from vexlabs. or were they just testing pieces to find out if the pieces would work or not. or are they simply bent these.
that robot is amazing, how much does it weigh? also what kind of sensor is pointed at the mini vision tetra?
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 08-11-2005, 13:51
artdutra04's Avatar
Thanks for the great comments everyone!!!
Originally Posted by tiffany34990
How fast does it take to extend up without the tetra on board?
Right now, the way it is geared, it takes about 12 seconds to fully raise. It seems a lot, but when you watch it, it actually seems quick. It used to be much faster, but I geared it slower to make it easier to control.
According to JVN, the linear bearing pieces may be available for purchase from VexLabs sometime in the next month or so. They are brand new pieces, that work excelent and have very low friction. They are 12 inches long, and comprise of an inner and an outer metal bearing piece. Here is another picture of them:
Right now, the robot weighs about 7 pounds. The sensor pointing at the mini vision tetra is the Vex Ultrasonic Sensor. I was using it to try to find the panels on the side of the vision tetra in autonomous, but with limites success. Even though it pans back and forth, the angle of the vision panels deflects the sound pings away. Unless the sensor is dead on, it never gets back a good reading because of the geometry of the vision tetra. (read: If you are ever trying to design an anti-radar aircraft - make a giant vision tetra )
How long will it be before I break the six-foot height for Vex?
Art Dutra IV
世上无难事,只怕有心人.
Unread 08-11-2005, 14:57
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Art... I must say you amaze me. I have been seeing your creations lately on chiefdelphi. This is the most effective vex robot I have seen for Triple Play. Very well designed and very creative.
I would guess in the next 2 weeks. Can't wait to see what's coming next.
Unread 08-11-2005, 19:56
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Sweet!
Unread 08-11-2005, 22:26
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
I wonder if the server rails we used in our tower/shuttle were the inspiration for these additions to the VEX line up? Or maybe it has something to do with Rack Solutions ties to VEX Labs. I'm sure john could clear this up for us.
JT
229
EDIT: For any of you who don't know, IFI, VEX Labs, Rack Solutions.com and Rack Solutions.co.uk are all part of Invovation FIRST, inc.
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 09-11-2005, 12:10
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
The server rails we used on 229 last year are from the Accuride 2907 series. These are low-friction slides using ball-bearings. (I used these rails last summer, during my RackSolutions internship. When we were designing our 2005 robot, I remembered them and integrated them into our elevator.)
The VexLABS-Slide Rails are patterned after a different (simpler), friction based design. (No bearings). That RackSolutions came up with for some of our medium duty applications. This design was easily adapated to Vex.
The basic design is that there are 2 "C" sections, which sit inside each other. They slide back and forth on their "corners" and not on their edges, which provides a happily low-friction motion, while maintaining good linear allignment. (See attachment.)
I'm very proud of this rail design, and can't wait to see it released as a product. Art certainly proved to us that it will be well utilized. We at VexLABS continue to be impressed by the high quality of his robot designs, and of his dedication to the Vex program.
Thanks Again Art!
-JV
pic: Vex Triple Play crazykid234 Extra Discussion 9 01-06-2005 17:39
pic: Vex before extending Not2B Extra Discussion 5 17-04-2005 22:01
pic: 2005 Vex Field dk5sm5luigi Extra Discussion 32 11-04-2005 12:27
pic: (447) Is this legal? rufu5 Robot Showcase 12 15-02-2005 21:52
pic: Is this currently legal or considered exotic? CD47-Bot Robot Showcase 10 13-05-2003 01:09
