Re: pic: gear boxes
That looks like somthing i would do. why are you guys being like me, its not good for you.
Re: pic: gear boxes
Well, I guess not not hard. I didn't personally see it happen, but boy did my jaw drop when I saw it. I know casting's are brittle, but that seems a little much. The gear box is completely useable, unless something else goes. Either way, we have two more of these if we have to replace it. Our mentor didn't completely trust these boxes, so bought spares. Guess he knew something!
So kids, remember: listen to your mentors, they might possibly not be totally wrong... |
Funny, I thought it only happened to us.
The same exact thing happened to us on our practice robot. It still worked when it was broken but we got it welded and although it doesn't look great it works fine. I ll try to post a picture. Dave |
Re: pic: gear boxes
When I first saw the picture I thought it was intentional to reduce weight. I had no clue that the casing was that brittle, that is very surprising.
Re: pic: gear boxes
Gotta wonder why exactly you'd be smacking the gearbox with a hammer...
at least get a mallet. |
Re: pic: gear boxes
Re: pic: gear boxes
Re: pic: gear boxes
all I have to say is wow...just goes to show that you need to watch all your hammers
Re: pic: gear boxes
Well I guess you figured out that the gearbox casting wasn't designed to take a hammer hit on the side walls. Those side walls were designed as thin as could be cast in order to keep the weight down. Under normal robot operating loads, that should never happen .......
#10
Re: pic: gear boxes
We had an unexplained fracture exactly like this which we ascribed to manufacturing fluke. We were just playing with the practice bot and some observant student noticed it had developed a fissure. This was less than an hour of use...
#11
Re: pic: gear boxes
as long as it dosent happen in the middle of a match
#12
Re: pic: gear boxes
Re: pic: gear boxes
Though I act like it's not my fault. The knowing are to blame when someone makes a mistake unknowingly. |
#14
Re: pic: gear boxes
I have to say...if those boxes are that weak...might be good to avoid them entirely. if they randomly break after little use I wonder if FIRST would replace them for you?
#15
Re: pic: gear boxes
| pic: 3 speed concept - 1st gear | sanddrag | Extra Discussion | 17 | 29-06-2005 17:30 |
| Need help designing keyway in gear | sanddrag | Technical Discussion | 17 | 31-01-2005 08:43 |
| pic: Team #1382 Teaser - Gear Box | tribotec_ca88 | Extra Discussion | 6 | 22-01-2005 20:02 |
| pic: 1126 Kocking down boxes and going after 1038 | CD47-Bot | Extra Discussion | 5 | 24-03-2003 06:45 |
| Drivetrain help | thedillybar | Technical Discussion | 9 | 08-01-2002 21:54 |
