Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
  #61   Spotlight this post!
Unread 02-11-2005, 23:29
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: pic: PS2 Driven Robot
So how about that source code?
I have been considering a similar project to convert USB HID->Gameport.
1139 Alumni
  #62   Spotlight this post!
Unread 03-11-2005, 22:11
Denalin Fusion's Avatar
Denalin Fusion Denalin Fusion is offline
FRC #0116 (εpsilon Δelta)
FTC #0018 (εpsilon Δelta)
Denalin Fusion is a splendid one to beholdDenalin Fusion is a splendid one to beholdDenalin Fusion is a splendid one to beholdDenalin Fusion is a splendid one to beholdDenalin Fusion is a splendid one to beholdDenalin Fusion is a splendid one to behold
Send a message via ICQ to Denalin Fusion Send a message via AIM to Denalin Fusion Send a message via MSN to Denalin Fusion Send a message via Yahoo to Denalin Fusion
Can you imagine controlling a robot on a DDR pad? Mehehe, it woudn't support tank mode, though.
Peachtree was a blast!
Hope to see you some other time: FRC 1002, FVC 80, FVC 117!
-Team 116-εpsilon Δelta-
~Dan Carew
  #63   Spotlight this post!
Unread 04-11-2005, 12:00
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
it would be pretty nifty if you could get the force feedback to work. Its always good to know where the problem lies and when it happens to imeadiately take counter measures. Unless it is very apparent like a sprocket flying out of your arm. Its kinda of hard to miss that while your driving.
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
  #64   Spotlight this post!
Unread 04-11-2005, 18:13
jakep jakep is offline
Software Engineer
AKA: Jake Poznanski
jakep has a spectacular aura aboutjakep has a spectacular aura about
Sorry for the lack of updates on this project. We have been having some problems with power supply through the OI, which makes us always fall back to external power. Once we get these things resolved, we will make the project code available.
  #65   Spotlight this post!
Unread 04-11-2005, 22:57
fuse's Avatar
fuse fuse is offline
fuse is an unknown quantity at this point
Ugh, i thought of using a ps2 controller 3 years ago and now i wish i had acted on it. I wish you guys luck though, it looks great so far. I was just planning on getting a bunch of adapters until i got to the game port, but i think getting your design legal would be a better approach. The weird thing is i have been soldering PICs on my team for like a year now and hadn't bothered to try what you guys are doing. Keep us updated as i think it is clear we all want to have this end good. (i sure would want to drive with one)
  #66   Spotlight this post!
Unread 07-11-2005, 10:38
mallot1243's Avatar
mallot1243 mallot1243 is offline
FRC #1243
mallot1243 is an unknown quantity at this point
How did you program it?
  #67   Spotlight this post!
Unread 14-11-2005, 22:16
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
I haven't been on Chief Delphi in a while and was suprised to see this topic as I did it in September. Its nice to see the same idea I had others had as well. But yeah I used http://www.levelsix.com/product_info.php?products_id=35 as my ps2 (well actualy I used my old ps1 controler) and it seemed to work great, there was a minimal amount of programming (just had to edit some of the input values). I really enjoyed the fact that I didn't have to program a dead zone as the anolog sticks automaticly returned to dead center (or close enough that it didn't matter in my case) ... the thing I don't understand is how people think this is against the rules, as the controller has the same setup as a joystick pretty much. The difference maily being that it has a rumble ability (which for some reason I am having trouble to program).
Well anyway against the rules or not thats what I did... I hope for my sake it isn't agaisnt the rules.
  #68   Spotlight this post!
Unread 15-11-2005, 19:11
fuse's Avatar
Originally Posted by d.courtney
I haven't been on Chief Delphi in a while and was suprised to see this topic as I did it in September. Its nice to see the same idea I had others had as well. But.........my sake it isn't agaisnt the rules.
Wait so how did you go from the parallel to the game port. Or did you modify it? Basically how did you connect your controller to the operator interface using that adapter?
  #69   Spotlight this post!
Unread 15-11-2005, 19:34
Umm Errr...
so.... how about that source you promised.....
1139 Alumni
  #70   Spotlight this post!
Unread 15-11-2005, 20:30
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Not2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond reputeNot2B has a reputation beyond repute
We have our team meeting tomorrow. I'll bug the Geek Team about it. See if I can get them to post the white paper they were working on.
I know they have it almost done... heck, they asked if they could get professionally made PCBs made... they better be close to done.
Brian Graham
  #71   Spotlight this post!
Unread 17-12-2005, 12:43
Software Engineer
AKA: Jake Poznanski
Alright, after being badgered by the team for a few months, we are finally getting everything together. We are currently working on a detailed whitepaper that explains everything you need to build one of these yourself, as well as about the history of the project (It wasn't easy to build this thing...) We will be making some changes to the sourcecode before that, since right now it has 0 comments and is impossible to understand.
We also want to get a PCB professionally printed.
I will keep everyone updated.
  #72   Spotlight this post!
Unread 27-01-2006, 16:08
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
White Paper has now been posted. This is competition legal as well!
Playstation 2 Controller Adapter
  #73   Spotlight this post!
Unread 26-01-2007, 02:01
sonofdad123 sonofdad123 is offline
FRC #0996 (Nerd-Uh-Knights)
sonofdad123 is an unknown quantity at this point
Originally Posted by Alan Anderson View Post
You said the same thing a couple of days ago, and my answer yesterday stands: The OI doesn't have any ports to which you can connect a serial joystick.
I actually have a 3D joystick with a serial interface; it's a Hewlett-Packard Spaceball. Few programs have the ability to use it as an input device.
technically all ports in the back of the computer are serial ports, except for the printer port which is parallel. the only difference besides connotation is the method in which data is sent and received. :-)
Team #996 Programmer/President/Comedy Relief
"Why not stop by the robotics meeting after school today?" -Mr. Murray (enlisting me)
  #74   Spotlight this post!
Unread 28-01-2007, 19:17
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Post Re: pic: PS2 Driven Robot
Where did you order the chips for the controller box from. The ones that go on the PCB board.
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
