Re: pic: Concept Gearbox
As said above, if you're going to invest so much time into machining the interface, you might be better off combining the CIM outputs before the transmission, thereby reducing weight, and money. Your setup might be lighter too. You have an awful lot of steel in those big gears! I'm pretty the Dewalts could handle the torque from two CIMs, but you'd have to check the specs.
Keep up the good Inventoring!
Reading makes a full man, conference a ready man, and writing an exact man. -Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Reason: Can't spell....
