Go to Post they used the same random number generator we used for our autonomous drive code . . . (oops did I say that?) - MrForbes [more]
Unread 16-11-2005, 22:10
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Re: pic: Concept Gearbox
Originally Posted by sanddrag
-Reduce the size of those gears and their hubs a considerable amount.
-Move the motors closer together and push that gear out from being inline. You'd end up with a triangle shape of sort with the center of each gear being a vertex of the triangle. (does anyone get this or did I make it too confusing? Sorry I can't describe it well)
- Find a better way to mount the motors and planetary combos. I think the current method isn't going to cut it. I think in the NBD setup, there is a plate between the CIM and DW tranny. I would modify this plate to look something like the ones in the KOP and mount the CIMS that way.
-How thick are the gearbox plates? I'd say anything over 1/4" is overkill.
-The gears are off the "shelf" from firstcadlibrary.com and probaley will purchase smaller for the actual assembly.
-I thought of moving the gears closer to each other to save space (one and 3 o'clock and one at 7 o'clock) but decided against it sice it might put too much troq unevenly spread over the center gear, and flexing the shaft.
-The NBD setup does have a plate between the moter and the tranny but i didnt make the actual dewalt trans i just used was a bosch i could find for the representation.
-The plates are 1/4.
Originally Posted by Tristan Lall
There's a small neutral band between the three ratios; try synchronizing the servos, or using one servo, with parallel links to each shifter.
We plan on using one servo to shift the dewalts. Just to mount the servo in the middle and use heavy gage wire (just to clairify not the kind you electronics box uses.) to attach to the shifters.
Thanks for all the input
Email me if you want any more pics since they are too big to attach
MechWarriors 573
pic: 195 Gearbox Tom Bottiglieri Robot Showcase 8 20-02-2005 00:21
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: 2004 TechnoKat gearbox CD47-Bot Robot Showcase 19 11-08-2004 21:26
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
pic: Gerrish Gearbox MKII CD47-Bot Extra Discussion 63 03-07-2003 00:06
