Go to Post Of course just because there is are existing solutions to a problem does not mean there aren't better ones. - dtengineering [more]
View Poll Results: Which of the 2 is more important?
Engineer/mentor designed and student built 83 61.94%
Student designed and Engineer/mentor built 51 38.06%
Voters: 134. You may not vote on this poll
Unread 17-11-2005, 21:36
Alex Golec Alex Golec is offline
FRC Advocate
no team (FiM Volunteer)
Alex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond reputeAlex Golec has a reputation beyond repute
Re: Student / Mentor, desgn/build Poll
Well, if I had had my pick, I would've chosen option #3: Students and Mentors work in perfect harmony to design and build the robot together.
However, the case being the two real options, I feel that both are similar in terms of pros and cons, but in the end I selected option 2: student designed, mentor built.
Before I begin with my reasoning, I will acknowledge that I am biased toward designing, and have followed in the footsteps of our team's engineer/designer, Art Ostrowski - designing has become my passion on the team. (I believe that this little bias was most likely the ultimate factor in my pick.)
First off, given the options, the students can gain much from both of the options: design and construction. In design, the challenge comes from deriving a solution, and conceptualizing a system for it. However, the actual construction of the system requires skill as well, in terms of correctly fabricating the parts and executing the assembly process correctly. Both are challenging to the students, and mentors are there to help in the processes.
To me, a robot designed by mentors may have great capabilities, but its assembly might be a bit rickety, and less reliable. A student built robot on the other hand, lacks some of the potential of a mentor designed robot: while it is somewhat true that students may not have been conformed to the "standard box of engineering" and can think outside of this box, the mentors usually have seen more machines, robots, and other implements and have a wider database of concepts to build off of already.
Additionally, FIRST is about a learning process, and in my experience with the team, I have been challenged more and learned more from designing a system than I have from constructing one. Imaginations are stretched in order to find some solutions, and for others the solution is marvelously simple - but both put to use multiple skills in conceptualizing and simplification of crazy contraptions into realistic, constructible systems.
In contrast of my general view, construction requires some finesse as well, not in creation, but in implementation. The first part drawing I ever received to make for a FIRST robot was a strange oblong oval with a square hole in the middle- it puzzled me to the point where I just sat and stared at it until our machinist came over and explained the part to me. I didn't quite get it then, so I was moved on to simpler parts. The most amazing design can never be implemented unless someone knows how to build it.
These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half."
Its a fair question, and a difficult one at that. Here are my two cents (2.4 cents Canadian, 1.7 euro cents), paid to CD challenging question fund.
_Alex
Former FIRST student and mentor dies in a tragic rocket attack in Iraq today. Munkaboo General Forum 48 19-04-2005 12:21
People i want to meet at the Championships '05 Heretic121 Championship Event 196 19-04-2005 08:56
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
High School Student to Mentor ratio Mr. Van General Forum 22 07-04-2004 12:59
University of Michigan student looking to mentor Jimmy Finding A Team 2 12-09-2003 09:51
