Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Unread 22-11-2005, 17:42
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: gear boxes
Originally Posted by Paul Copioli
Well I guess you figured out that the gearbox casting wasn't designed to take a hammer hit on the side walls. Those side walls were designed as thin as could be cast in order to keep the weight down. Under normal robot operating loads, that should never happen .......
Well, yeah, you're completely right. Something we should all take away from this then...: Never underestimate the um...ability.... of students in small groups.
Though I act like it's not my fault. The knowing are to blame when someone makes a mistake unknowingly.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 23-11-2005, 13:37
alphastryk's Avatar
alphastryk alphastryk is offline
1002 Student Leader
AKA: Brian Plattenburg
FRC #1002 (Circuitrunners)
alphastryk is an unknown quantity at this point
Send a message via AIM to alphastryk Send a message via MSN to alphastryk Send a message via Yahoo to alphastryk
Re: pic: gear boxes
I have to say...if those boxes are that weak...might be good to avoid them entirely. if they randomly break after little use I wonder if FIRST would replace them for you?
Team 1002 - Wheeler High Circuit Runners
Marietta Georgia - www.circuitrunners.com
-2006 Chairman's Award Winner - Peachtree Reigonal
-2005 Chairman's Award Winner - Peachtree Regional
-2004 Chairman's Award Winner - Peachtree Regional
-2004 Chairman's Award Honorable Mention - Atlanta Championship Competition
-2004 Competition Winner - Peachtree Regional - Undefeated in 6 straight playoff matches
-2004 DaimlerChrysler Team Spirit Award - Peachtree Regional
-2004 Kleiner, Perkins, Caufield & Byers Entrepreneurship Award - VCU Regional
-2004 Website Excellence Award
-2003 Rookie All Star - Peachtree Regional
-2003 Johnson & Johnson Sportsmanship Award - Peachtreee Regional-
Unread 23-11-2005, 14:57
FRC #0306 (CRT)
Re: pic: gear boxes
Well, thing is, they don't break randomly. Castings are generally brittle, and a hard strike will crack them. We have spares, and it's not affecting operation.
-Sir Francis Bacon
-Albert Einstein
Unread 23-11-2005, 18:44
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: gear boxes
...or it might be good to avoid doing stupid things like smashing a thin metal casing with a steel hammer...
Just a thought...
2001-2004: Team 100
2006-Present: Team 254
pic: 3 speed concept - 1st gear sanddrag Extra Discussion 17 29-06-2005 17:30
Need help designing keyway in gear sanddrag Technical Discussion 17 31-01-2005 08:43
pic: Team #1382 Teaser - Gear Box tribotec_ca88 Extra Discussion 6 22-01-2005 20:02
pic: 1126 Kocking down boxes and going after 1038 CD47-Bot Extra Discussion 5 24-03-2003 06:45
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
