Go to Post Teach 'em young, and they will go far. - Vashts6583 [more]
Unread 01-12-2005, 19:11
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Re: White Paper Discuss: Eclipse for Robotics
Originally Posted by Astronouth7303
Even after I downloaded the updated file, it still doesn't work for me.
I look at the "Plug-in Details" dialog from the About dialog, and the Plug-in IDs go straight from "org.eclipse.cdt.managedbuilder.ui" to "org.eclipse.cdt.refactoring".
Extracting it into a folder doesn't help. (The dir has since been removed.)
Eclipse:
Version: 3.1.0
Build id: I20050627-1435
The only error in the error log I can find is this:
Code:
!ENTRY org.eclipse.update.configurator 2005-11-30 17:45:06.320
!MESSAGE Could not install bundle plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0/   Bundle "org.eclipse.cdt.mcc18.toolchain" version "1.2.0" has already been installed from: update@plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0.jar
In the configuration details, I see:
Code:
org.eclipse.cdt.mcc18.toolchain (1.2.0) "Microchip C18 Compiler Tool Suite Managed Make Extension" [Installed]
Code:
  file:/d:/Program Files/Eclipse/plugins/org.eclipse.cdt.mcc18.toolchain_1.2.0.jar
What the heck is going on?
Very odd.
I've never actually read the error messages. (It always worked for me, so I'm not sure what they mean.)
Try starting eclipse with the option -clean.
Are you sure that you're CDT installation worked?
Becauser there should be plugins like org.eclipse.cdt.core, etc.
In other words can you create a GNU C/C++ Project?
If not, then delete all the files in the plugin directory that have org.eclipse.cdt.*
and anything related to CDT in the features directory.
Then download CDT from CDT's download site. An unzip the file and copy the appropriate files to your plugin and features directory. Then start eclipse with the clean option again.
If this doesn't work I'll try posting this problem in CDT's newsgroup.
Unread 01-12-2005, 19:16
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Talking Re: White Paper Discuss: Eclipse for Robotics
Originally Posted by prograid
Very odd.
That did it. Thank you.
Unread 01-12-2005, 19:22
AKA: Jamie Bliss
Bug: Include paths wrong
Ok, new bug.
You don't use the enviroment variable MCC_INCLUDE. You appear to hard-code C:/mcc18/h. (A false assumption; I have mine installed to D:\mcc18\h)
I also can't find an option to change it.
Unread 01-12-2005, 22:55
prograid's Avatar
AKA: Ben Cherian
Re: Bug: Include paths wrong
Ok, new bug.
Thank you for telling me that, I didn't know about MCC_INCLUDE, but you still can change it. Go to project properties C/C++ Build Settings. Look at Compilation Information, under the C18 Compiler heading of the Tool Settings tab, Change the Include path from C:\mcc18\h to D:\mcc18\h.
Unread 03-12-2005, 17:00
AKA: Jamie Bliss
I've now discovered something else.
If you use the MinGW make, it will mung the command, so that it calls:
Code:
mplink ..\18F8520user.lkr w:/ m:/ FRCMapfile.map D:/msys/1.0/odefault_2005.hex ./ifi_startup.o ./ifi_utilities.o ./main.o ./printf_lib.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /lD:/mcc18/lib ..\FRC_Library.lib
Cygwin's make does not exhibit this behavior.
Unread 06-12-2005, 21:50
prograid's Avatar
AKA: Ben Cherian
Code:
Sorry, about taking so long to reply.
It could be because you have both make programs installed.
I'm using MinGW's make and I have the following output (using Eclipse 3.1.1 and CDT 3.0.1)
Code:
mplink "..\18F8520user.lkr" /a INHX32 /w /m FRCMapfile.map /oRoboticsCode.hex  ./254_arm.o ./254_drive.o ./254_encoder.o ./254_gyro.o ./254_interrupts.o ./254_timers.o ./254_utilities.o ./eeprom.o ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_camera.o ./user_routines.o ./user_routines_fast.o   /l"C:\mcc18\lib" "..\FRC_Library.lib"
Unread 06-12-2005, 22:06
AKA: Jamie Bliss
Code:
I actually had to grab that by some script hooks (so it would show me the command).
The output is something like "invalid input: m:\". It still prints the command it's supposed to send. It's munging on make's part. (I looked at the generated file. The command was correct.)
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: 2005 IRI - Everything You Need to Know (or at least most of it) Chris Fultz Off-Season Events 3 17-05-2005 20:14
White Paper Discuss: Sponsor Care Presentation Chris Fultz Extra Discussion 0 25-04-2005 12:51
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
