Bug: Include paths wrong
Ok, new bug.
You don't use the enviroment variable MCC_INCLUDE. You appear to hard-code C:/mcc18/h. (A false assumption; I have mine installed to D:\mcc18\h) I also can't find an option to change it. |
Re: Bug: Include paths wrong
Re: White Paper Discuss: Eclipse for Robotics
I've now discovered something else.
If you use the MinGW make, it will mung the command, so that it calls: Code:
mplink ..\18F8520user.lkr w:/ m:/ FRCMapfile.map D:/msys/1.0/odefault_2005.hex ./ifi_startup.o ./ifi_utilities.o ./main.o ./printf_lib.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /lD:/mcc18/lib ..\FRC_Library.lib |
It could be because you have both make programs installed. I'm using MinGW's make and I have the following output (using Eclipse 3.1.1 and CDT 3.0.1) Code:
mplink "..\18F8520user.lkr" /a INHX32 /w /m FRCMapfile.map /oRoboticsCode.hex ./254_arm.o ./254_drive.o ./254_encoder.o ./254_gyro.o ./254_interrupts.o ./254_timers.o ./254_utilities.o ./eeprom.o ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_camera.o ./user_routines.o ./user_routines_fast.o /l"C:\mcc18\lib" "..\FRC_Library.lib" Last edited by prograid : 06-12-2005 at 21:53. Reason: Wrong code |
The output is something like "invalid input: m:\". It still prints the command it's supposed to send. It's munging on make's part. (I looked at the generated file. The command was correct.) |
| White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team | Jessica Boucher | Extra Discussion | 1 | 20-11-2005 20:01 |
| White Paper Discuss: 2005 IRI - Everything You Need to Know (or at least most of it) | Chris Fultz | Off-Season Events | 3 | 17-05-2005 20:14 |
| White Paper Discuss: Sponsor Care Presentation | Chris Fultz | Extra Discussion | 0 | 25-04-2005 12:51 |
| White Paper Discuss: Joystick Sensitivity Demystified - Version 2 | marccenter | Extra Discussion | 0 | 28-02-2005 16:54 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
