Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Unread 01-12-2005, 22:55
prograid's Avatar
prograid prograid is offline
AKA: Ben Cherian
prograid will become famous soon enough
Re: Bug: Include paths wrong
Originally Posted by Astronouth7303
Ok, new bug.
You don't use the enviroment variable MCC_INCLUDE. You appear to hard-code C:/mcc18/h. (A false assumption; I have mine installed to D:\mcc18\h)
I also can't find an option to change it.
Thank you for telling me that, I didn't know about MCC_INCLUDE, but you still can change it. Go to project properties C/C++ Build Settings. Look at Compilation Information, under the C18 Compiler heading of the Tool Settings tab, Change the Include path from C:\mcc18\h to D:\mcc18\h.
Unread 03-12-2005, 17:00
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: White Paper Discuss: Eclipse for Robotics
I've now discovered something else.
If you use the MinGW make, it will mung the command, so that it calls:
Code:
mplink ..\18F8520user.lkr w:/ m:/ FRCMapfile.map D:/msys/1.0/odefault_2005.hex ./ifi_startup.o ./ifi_utilities.o ./main.o ./printf_lib.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /lD:/mcc18/lib ..\FRC_Library.lib
Cygwin's make does not exhibit this behavior.
Unread 06-12-2005, 21:50
prograid's Avatar
AKA: Ben Cherian
Code:
Sorry, about taking so long to reply.
It could be because you have both make programs installed.
I'm using MinGW's make and I have the following output (using Eclipse 3.1.1 and CDT 3.0.1)
Code:
mplink "..\18F8520user.lkr" /a INHX32 /w /m FRCMapfile.map /oRoboticsCode.hex  ./254_arm.o ./254_drive.o ./254_encoder.o ./254_gyro.o ./254_interrupts.o ./254_timers.o ./254_utilities.o ./eeprom.o ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_camera.o ./user_routines.o ./user_routines_fast.o   /l"C:\mcc18\lib" "..\FRC_Library.lib"
Unread 06-12-2005, 22:06
AKA: Jamie Bliss
Code:
I actually had to grab that by some script hooks (so it would show me the command).
The output is something like "invalid input: m:\". It still prints the command it's supposed to send. It's munging on make's part. (I looked at the generated file. The command was correct.)
White Paper Discuss: NEMO White Paper: 25 Ways Sponsors Can Help Your Team Jessica Boucher Extra Discussion 1 20-11-2005 20:01
White Paper Discuss: 2005 IRI - Everything You Need to Know (or at least most of it) Chris Fultz Off-Season Events 3 17-05-2005 20:14
White Paper Discuss: Sponsor Care Presentation Chris Fultz Extra Discussion 0 25-04-2005 12:51
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
