Re: pic: IFI's new wheels on Denominator
What is the coefficient of friction for these wheels and how often do you have to change the treads (if at all)? How much do they weigh btw, the website did not indicate. These wheels look great!!
GO 1403!!! |
I too am interested in the weight. I couldn't afford anything more than probably .65 lbs per wheel assembled.
For tread wear, they are so wide that your ground pressure becomes pretty low and so does the wear. Unless you are spinning for the entire match, I think they should last at least a regional, if not two. |
Here is one of the videos that we took during testing.
http://www.vexlabs.com/video/IFI-Wheel_test.wmv |
Chris,
I like the spacers you used to locate the wheels on the axle...good stuff. rob |
Hey, we had a similar desgin last year.
here's apicture of it ![]() |
| pic: Easy to make mecanum wheels | mechanicalbrain | Extra Discussion | 15 | 06-10-2005 21:37 |
| pic: IFI's New Vex Robot | JVN | Extra Discussion | 18 | 20-07-2005 23:24 |
| Programming a 2nd PIC | ImmortalAres | Programming | 8 | 16-06-2005 12:13 |
| pic: 222's wheels | CD47-Bot | Robot Showcase | 14 | 11-12-2003 08:14 |
| wheels ! | Martin | Technical Discussion | 2 | 09-01-2002 16:08 |
