Go to Post My suggestion is to first focus in on your drive base. Get it running, and drive it into the ground and see what breaks. Then fix it. Rinse wash and repeat. - Andy A. [more]
Unread 05-12-2005, 20:45
slickguy2007 slickguy2007 is offline
Copioli is the man!!!
FRC #1403 (Cougar Robotics)
Rookie Year: 1997
slickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond reputeslickguy2007 has a reputation beyond repute
Send a message via AIM to slickguy2007
Re: pic: IFI's new wheels on Denominator
What is the coefficient of friction for these wheels and how often do you have to change the treads (if at all)? How much do they weigh btw, the website did not indicate. These wheels look great!!
GO 1403!!!
Team 1403 is Proudly Sponsored By:
Unread 05-12-2005, 21:04
I too am interested in the weight. I couldn't afford anything more than probably .65 lbs per wheel assembled.
For tread wear, they are so wide that your ground pressure becomes pretty low and so does the wear. Unless you are spinning for the entire match, I think they should last at least a regional, if not two.
Unread 05-12-2005, 21:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
GO 1403!!!
1.2-1.3 ish.
2001-2004: Team 100
2006-Present: Team 254
Unread 06-12-2005, 11:55
Adrienne E. Adrienne E. is offline
New Yorker turned Texan
Adrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond reputeAdrienne E. has a reputation beyond repute
Here is one of the videos that we took during testing.
http://www.vexlabs.com/video/IFI-Wheel_test.wmv
Adrienne Emerson
191 Alumni 2000-2002
229 Alumni 2003-2006
148 2009-Present
Unread 06-12-2005, 15:03
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Chris,
I like the spacers you used to locate the wheels on the axle...good stuff.
rob
Unread 07-12-2005, 12:19
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
Hey, we had a similar desgin last year.
here's apicture of it
pic: Easy to make mecanum wheels mechanicalbrain Extra Discussion 15 06-10-2005 21:37
pic: IFI's New Vex Robot JVN Extra Discussion 18 20-07-2005 23:24
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
wheels ! Martin Technical Discussion 2 09-01-2002 16:08
