Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
Unread 29-04-2005, 13:28
Mark Jones Mark Jones is offline
Engineer - Team 343 MIM
FRC #0343 (Metal-in-Motion)
Mark Jones will become famous soon enoughMark Jones will become famous soon enough
Send a message via AIM to Mark Jones
pic: Reworked AndyMark Gearbox
Unread 29-04-2005, 13:30
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: Reworked AndyMark Gearbox
That is really cool. I am surprised A&M didn't sell a servo shift version. Was it difficult to adapt one? Also, how much weight did you save with the modifications and removing the cylinder?
Team 1257
Unread 29-04-2005, 13:38
Saved about 3lbs per gearbox. I cut new side plates from .125 aluminum.
I just made a bracket to mount the servo and a servo shifting fork. I simply cut one of the supplied 3" long 10/32 bolts and made a new shifting rod in which I sandwiched a bronze flanged bushing between two 10/32 nylock nuts.
Unread 29-04-2005, 14:40
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
How does the servo hold up? Any problems or irregularaties compared to the pnumatic system? Have you tested it at full speed? I'm just wondering since the servos seem a little more weak and brittle compared to the pnumatic pistons.
Unread 29-04-2005, 15:09
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
I saw you adding those plates at Palmetto. Very cool. Seems you guys don't rest. But necessity (weight reduction in this case) breeds invention. When I see this, it makes me want my 2006 AM shifters to come like that. So the question is, say AM decides to make this an option. Do we have to pay 343 (or you Mark) royalties? Or are you going to let Andy and Mark benefit from your creativity? And Andy are you already on this page? Although the steel channel side plates probably help Andy and Mark to sleep at night as far as the safety factor margins. Losing 6 lbs is a big deal... Nice work Mark!
www.179swampthing.org
Unread 29-04-2005, 15:21
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
there are 2 holes on each side of the servo ... They are screwed on to that aluminum plate with 4 screws.
Unread 29-04-2005, 16:34
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
These are good questions. Mark and team 343 has a great implementation of this idea. Their fork coupling is very elegant.
Keep in mind that there are some prior designs: Matt Reiland and team 226 have shifted their dog gears with servos for a couple of years. Also, back in 2000, we (team 45) shifted the Bosch gearbox with a servo.
We at AndyMark are working on a new, improved, less expensive AM Shifter for 2006. However, we still will offer our 2005 version.
Andy B.
Last edited by Andy Baker : 29-04-2005 at 17:41. Reason: improved marketing terms (changed "cheaper" to "less expensive")
Unread 29-04-2005, 17:39
We at AndyMark are working on a new, improved, cheaper AM Shifter for 2006. However, we still will offer our 2005 version.
Andy B.
Andy....I wouldn't use the word "cheaper"...."less expensive" sounds much better for a quality product such as yours. (so are your going to out-source the assembly to Mexico??)
Dan...Andy's right. If you purchased some DeWalt gearboxes and adapted them for another application, would you pay royalties to DeWalt or Joe Johnson???
Once you make the purchase, they are yours to do with as you want. We purchased the AndyMarks b/c our machining resources were slim this year and we got an outrageous quote to machine some stock gears. The AM's were are bargain. Since we had already shipped the robot, the lesser of the two evils was to modify the AM's to meet our drive application. While I was at it, I made a few more modification to meet our specific needs.
Let's see what Andy and Mark have in store for the 2006 models. Meanwhile, I see what I can do to put together a white paper illustrating the servo shifting mod.
Note to self....must talk to Andy Baker.....where does he find time to devote to all that he does???
Unread 29-04-2005, 18:05
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
very elegant combination of 2 great ideas, servo shifting and the AM gearbox. Do you have any of that in a cad? I'd like to see how you designed the shifting mechanism, as simple as it is.
Unread 29-04-2005, 22:51
Swampdude's Avatar
AKA: Dan Quiggle
Eh.. I was J/K. anyhow I think DeWalt owes Joe some cash for all the NBD business he brought in. But just think, if Andy gets the Shifters made in China/Mexico for $15ea, you can get in the loop with AM2 hop up kits.
I think Dean would get upset if you guys start outsourcing this venture though. So make sure you use American kids.
Unread 07-12-2005, 19:02
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Andy B.
Andy,
Is the "new, improved, less expensive AM shifter for 2006" still in the works? If so, any idea when will it be ready for the street? Maybe a sneaky peeky pic or two could dift on to this thread???? Jan 7th is just around the corner...
Unread 07-12-2005, 19:20
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
i think he means how does it hold up as in how durable is it?
which i think wont be too bad at all. i think an rc car's servo will see more abuse than this. you steer (or work the throttle/brakes) a lot more than you shift gears.
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
I think it materialized into their new single speed transmission, maybe citing cost to make/assemble, or robustness.
http://www.andymark.biz/am-gearbox.htm
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 07-12-2005, 19:33
Originally Posted by DeepWater
Andy,
The price has been lowered from (I believe) previously $365 to the new price of $330. The price on the Fisher Price planetary has been lowered as well.
Unread 07-12-2005, 22:37
Jno
FRC #0610 (Crescent Robotics)
My team, 610, has been researching into different gearbox's and were planing on ordering one of the AM 2-speed gearbox's until I can across this information about a newer design. I was wondering if you could give us a time frame of when these gearbox's will be available, before new year? and possibly a price range, will it be silmilar to the older version?
pic: 195 Gearbox Tom Bottiglieri Robot Showcase 8 20-02-2005 00:21
Looking for KoP Drill motor gearbox parts Max Lobovsky Kit & Additional Hardware 2 09-08-2004 20:06
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
pic: Gerrish Gearbox MK-III CD47-Bot Extra Discussion 22 04-09-2003 16:32
pic: Gerrish Gearbox MKII CD47-Bot Extra Discussion 63 03-07-2003 00:06
