Go to Post Find what your team is good at, and use it in any way you can. - karomata [more]
Unread 09-12-2005, 15:17
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Measure Thrice
Originally Posted by Richard
Three challenges:
1) Provide an alternate description of the solid using two words.
2) Describe a procedure for fabricating the solid.
3) Describe a procedure for modelling the solid in Inventor.
1: chisel tip?
2: Cut a 1" length of 1" rod. Mark a vertical diameter on one end, and a horizontal diameter on the other. Grind off material such that the ground faces become half-ellipses, so that the curved "end" touches the tip of the horizontal diamter and the straight "end" is the vertical diameter.
(It might be easier and/or safer to do the grinding first, then the cutting. It is also possible to cut the diagonals rather than to grind them off.)
3: Extrude a 1" circle, a 1" square, and the 1"x1" triangle. Intersect them all at right angles (e.g. cylinder along the x axis, square prism along the y axis, and triangular prism along the z axis).
Unread 09-12-2005, 16:18
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
This is a very cool site that contains drawings a ton of polygons. It also has 3D color pictures that can be rotated of polyhedrons of varying complexity, I found one that looks like the Epcot center.
On to the goods
1.) Omni Cork Plug
2.) Put a screw in the bottom of a 1x1 cylinder and hold it verticly ^ (when its done) sorta like that drawn and mill out the triangle shape.
3.) Extrude a 1in. Dia. Cylinder, with a 60 deg. taper, 1in.
Looking at this site i described above i noticed that on the square face the piece removed by the triangle is a perfect parabola.
Unread 09-12-2005, 16:39
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Actually, that would have to be a half ellipse, since the two extremes are parallel. The sides of a parabola never reach parallel.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 09-12-2005, 16:40
Chinese Screwdriver?!
Unread 09-12-2005, 20:53
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Good guess.
Originally Posted by Alan Anderson
1: chisel tip?
That's the one I was looking for.
Originally Posted by Bill Hancock
This one is the probably the best. Note that the mathworld link says there is an infinite family of shapes that satisfy the challenge. The one with minimum volume has triangular cross sections.
I think the mimimum volume cork plug can be (approximately) modelled in Inventor as a loft from a thin rectangle one inch long by 1/1000th inch wide to a one inch diameter circle. The rectangle is sketched on a plane one inch from the circle and the long centerline of the rectangle projects onto the circle's diameter. I used a model made this way to generate an STP file from which we made a "minimum volume" cork plug on a Viper SLA machine at Emerson.
Of course, Alan's procedure is more practical. Just round the elliptical edges a bit and you end up pretty close to the minimum volume.
Richard Wallace
since 2003
Unread 09-12-2005, 20:46
AKA: Bill Hancock
If you were to extend the length on the main cylindrical feature the extremes would be parallel, but if you to expand the height and width so that the poece would always be a perfect square the sides of the parabola would just be intersecting with the corners of the square shape and would continue in a parabolic "line"
MechWarriors 573
Unread 09-12-2005, 21:10
GW is right. The curved edge is elliptical, not parabolic. Referring again to the the mathworld site, an ellipse is a section through a cylinder (a circle is the special case in which the section plane is perpendicular to the cylinder's axis), while a parabola is a conic section (section through a cone).
Richard Wallace
since 2003
Unread 10-12-2005, 23:43
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Correct. Specifically, a parabola is the special case where the section plane is parallel to one "edge" of the cone, so that the curve never closes on itself: http://mathworld.wolfram.com/ConicSection.html
Unread 30-01-2006, 17:12
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
If you make this like the way everyone else is wouldn't there me more lines on the triangle? They wouldnt be hidden lines because they are outside of the projection of the triangle face.
Unread 09-12-2005, 16:51
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Epcot's Spaceship Earth is the world's largest complete geodesic sphere. There are many other geodesic domes scattered around the world and a sphere or two, as well.
--Madison--
...down at the Ozdust!
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
Tape measure proboscus tito General Forum 24 29-04-2002 15:56
