Go to Post and isn't this fun? :) CD is great :D - rick.oliver [more]
Unread 16-12-2005, 11:39
REVving up for a new season
FRC #2848 (All-sparks)
compiling in MPlab
so this is going to sound really dumb but remember that i am a mechanical guy. I am working on a project where we need update the code that someone has already written but we can't seem to figure out how to compile the code. We are using MPlab 7.1 anyone want to point me in the direction of the correct button.
P.S. if this works i will post a picture of what we are doing...it is worth it
Greg Needel│www.robogreg.com
Unread 16-12-2005, 11:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: compiling in MPlab
Originally Posted by Greg Needel
...we can't seem to figure out how to compile the code. We are using MPlab 7.1 anyone want to point me in the direction of the correct button.
I think what you're looking for is the Make option in the Project menu. If I recall correctly, F10 works as a shortcut.
(You need to choose Project -> Open... first and select the proper .mcp file, so the IDE knows what program files you're working with and how to compile them.)
Unread 16-12-2005, 12:43
thanks, that was the solution, we had just opened the .c code without the project being open so it wasn't giving us that option. It worked...now we just need to tweek some variables.
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
