Re: White Paper Discuss: Team 33 Four Speed Transmission
It is not an extension. Cut off a 1.375" piece of the 12T spur gear stock and turn the gear teeth off 1" of it. It is one piece. The other gear is bored and fit over the turned down section and welded on.
This link no longer works, would it be possible for someone else to post these files,
To fix the file, download the file and change the extention from .htm to .doc.
has anyone reliably shifted this transmission non pneumatically?
out team has developed the habit of never using pneumatics just because of the added weight from putting on tanks and possibly the compressor. just wondering also the link to the inventor files doesn't seem to be up anymore Last edited by Aren_Hill : 16-09-2007 at 15:05. |
The pneumatics vs. motor debate is an old one, and best saved for another thread, but if you did happen to have pneumatics on your robot, I would suggest using them to shift, but if you didn't it probably wouldn't be worth installing pneumatics just for shifting capabilities. |
| White Paper Discuss: Team 188 Woburn Robotics 2004 Gearbox Design Report | CD47-Bot | Extra Discussion | 5 | 17-03-2009 18:45 |
| White Paper Discuss: An Introduction to C Programming for First Robotics Applications | CD47-Bot | Extra Discussion | 10 | 26-11-2004 21:54 |
| White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission | CD47-Bot | Extra Discussion | 4 | 14-07-2004 15:43 |
| White Paper Discuss: Chief Delphi Segway Fundraiser Info | CD47-Bot | Extra Discussion | 1 | 21-06-2004 09:48 |
| White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox | CD47-Bot | Extra Discussion | 35 | 23-01-2004 20:16 |
