Go to Post Yes, no more dancing. Robots is serious business :rolleyes: - wilsonmw04 [more]
Unread 01-01-2006, 22:12
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Re: Rookie Team 1746 creates it's first prototype robot
Looks great guys. and Kyle is definitely right, K.I.S.S. all the way. As for the problem of the bot veering to the left slightly, from what I can tell you have you axle mounts mounted directly to the 80-20. You may want to check that your 2 drive wheels are spaced exactly the same position on the chassis for both sides, if they aren't that may be what is causing your problem.
JT
229
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 01-01-2006, 22:35
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Yes check on the spacing. When we used the 80/20 back in 2001 for our robot we had to check them every so often because they loved to slide on us. Also be careful with the 2 wheel drive robot, especially if you get into a pushing match with a team since yours could possible spin easier than one that is 4 wheel.
Also there I haven't searched through the White Papers on drive trains or other mechanisms lately so I'm not completely up to date on what they have. But i do know that if you are interested in researching drive trains there are a few helpful pieces that JVN wrote up on our teams website. One of them is here:
http://team229.org/resources/single/181
Good luck to you guys in the up coming season. Hope to see you guys doing well at the regional(s) you attend. Remember to K.I.S.S. and you guys will do fine.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 01-01-2006, 22:44
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Looks like you have a very good start Snappel!
Concerning the drive train, you may want to be aware of whether or not your drive train meets the demands of the game. What you have here is great for a game that requires maneuverability and good offense (such as this past years' game), but I would not recommend this setup (2 wheel drive with casters) for a game that was highly defensive and required your robot to push another robot or drive up an inclined surface (any veteran teams out there remember the "caster-bots" of 2003 and how they would often veer off to the side while trying to get up the ramp?)
The same principles that make 2 wheel drive robots extremely maneuverable are the same ones that make them easy to push around. If this coming year's game requires alot of defense (bots pushing other bots), I would not recommend going with this setup. Instead, I would go with a 4 wheel drive setup instead.
Originally Posted by Snappel328
We tried a 4 wheel drive in our kitbot, not that one, and it was very difficult to get bot to do a gradual turn to the left or right while moving forward. We eventually took those off and use giant ball-bearing wheels in the final design of our kitbot. We used the same ball-bearing wheels on Brutus, but in the front and back while we used the drive-wheels in the middle.
Perhaps you know this already, but by altering what is called the "track" and the "wheel base" of a four wheel drive robot, you can achieve different degrees of maneuverability. Here is a paint sketch illustrating this:
Perhaps the first time you tried building a 4 wheel drive, your track was too short in comparison to your wheel base. You can try adjusting the ratio of track to wheel base until you find a perfect balance between maneuverability and pushing ability. I would recommend this setup for dealing with inclined surfaces (such as ramps), as well as defensive ones, so that your robot won't have difficulty climbing them.
Of course, there are alternatives to this design. You could go with a six wheel drive robot, with its middle wheel slightly lower than the rest, which would give it both a high degree of maneuverability as well as pushing power. Or you could try omni wheels, swerve drive, mecanum wheels... etc. However, the 4 wheel drive design is the simplest available in comparison to the others... and as rookies, it is best for you to stick with simple designs that you can master before progressing to the next level of complexity in design. I believe someone has already said it, but I will say it again: K. I. S. S. (Keep It Simple Silly)! Oftentimes, the simplest ideas are the best ones.
Good luck,
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 02-01-2006, 14:14
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
BurningQuestion has a lot of great information. The bottom line is that simple 4WD skid steering has to overcome the friction of the wheels to slide them sideways. Thinner wheels, omni wheels, shorter wheelbase vs track are all ways to reduce the effect of the wheels skiding sideways. Engineering is all about compromise and designing for the task that the competition presents.
Looks like you guys are of to a great start.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 03-01-2006, 08:12
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Scared of a rookie team?
"Rookie" just means you are new to the game, not that your team isn't as skilled as many already in the competition.
Last years final rookie team in FRC, 1708 from McKeesport, PA, was a Regional Champion at Pittsburgh. You may be surprised at how well your team does this year, but most veterans won't. We've seen talented rookies come in every year and play at very high levels of competition.
Good luck, and enjoy your season!
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 04-01-2006, 16:03
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
This looks really good. Do you have last year's FRC Robot Controller on it?
P.S.
Always have safety glasses on when having a picture of you working with the robot.They almost disqualified a team in last year's Israeli regionals because of that.
I heart FIRST
2005- Israeli regional champions
2006-Israeli regional- champion alliance, innovation in control award, entrepreneurship award, woody flowers award
Championship event-14th on Curie, backup #4 on elimination
1574 Rocks
i turned into a mentor
Unread 04-01-2006, 21:50
Sepsis900's Avatar
Sepsis900 Sepsis900 is offline
professional...er...I build robots
AKA: Alex Bachmanov
FRC #0321 (Robolancers)
Sepsis900 is an unknown quantity at this point
Send a message via AIM to Sepsis900 Send a message via Yahoo to Sepsis900
Wonderful robot! Remember to design the robot specifically for its task in the competition. a 2-wheel drive is simple and reliable on flat ground, but helpless on a ramp, or even if something is stuck under it. Conversely, a four-wheel drive might work well on ramps, but can't turn to save its life. Make sure to keep a low center of gravity too, and ween yourselves off 80/20 as soon as someone can weld a chassis for you! Squared aluminum tubing is much lighter.
That, and creative programming can solve almost any problem.
That's my advice for you, good luck!
[WHUMP]
"...That's a feature. Our robot plays dead."
[CLUNK]
"The arm just fell off"
"That's another feature!"
Unread 05-01-2006, 17:53
Chase's Avatar
Chase Chase is offline
Construction/Photographer
AKA: Chase
FRC #1546 (CHAOS INC.)
Team Role: Student
Chase will become famous soon enough
Send a message via AIM to Chase
You said one month, at 2 days a week? Wow! I hope build season goes just as smoothly for you guys. I wouldn't be the least bit suprised if you guys made it to Atlanta. Good luck!
CHAOS INC. Team #1546
2005-Long Island Regional-Rookie Allstar Award
2006-Long Island Regional-Sportsmanship Award
I was going to list all the funny quotes I've collected from our team over the past few years, but I have way too many.
"I don't care how you do it, we need to raise money. Jump a freshman..." -Ms. Reiss
Attending: Deer Park Invitational, Brunswick Eruption 2006, SBPLI Long Island regional, Championship Event?
Ban Comic Sans
Unread 08-01-2006, 22:24
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
Originally Posted by billbo911
Wow, that is really well done, and only one month at 2 days per week to build! I would love to have our team that motivated this year.
I also would like some feedback on your drive train. That is almost identical to what I have been envisioning for one of our future (near future I hope) designs. My belief is that it would be highly maneuverable and fairly responsive. Is that what you are finding? Also, do the casters cause any problems or are there any other drawbacks you have been experiencing?
last year we used ACME casters
http://www.constantines.com/browsepr...e-Casters.HTML
they also make some with plastic insted of steel ball bearings - which is what we used because they'll a lot lighter. they handle super smooth
Teams I would like to recognize for excellent designs this year. b-rant General Forum 36 05-12-2005 15:04
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
