Go to Post While those ideals might exist in black and white perfection; in the real world, with very rare exception, they can only be implemented as compromises in shades of gray. - gblake [more]
Unread 03-01-2006, 11:03
kc8nod's Avatar
kc8nod kc8nod is offline
AKA: Ted Hansen
FRC #1216 (Knights)
kc8nod is on a distinguished road
Re: White Paper Discuss: Handy script to examine the size of your code
Originally Posted by prograid
...the script is being run as a post-build command from within eclipse.
Sorry for the slow response, I've been offline last week.
I'm guessing that you are doing something clever with your linker script and that is confusing the codsize script. Are you even using the linker script? I can only imagine what hacks you have had to perpetrate to make mcc18 work under Eclipse. Anyway, from your mapfile:
Code:
                              Program Memory Usage
                               Start         End
                            0x000800    0x000814
                            0x000818    0x0063a0
                            0x300000    0x30000d
            23468 out of 33816 program addresses used, program memory utilization is 69%
My codesize script is improperly concluding that your program ends at address 0x000814 rather than 0x0063a0. My unfounded guess is that you have an extra CODEPAGE entry in your .lkr file.
At any rate, the bug is indeed in my script. I'll think about this a bit more and post a fix in a day or two.
White Paper Discuss: 2003 Automated Dead Reckoning Test Code CD47-Bot Extra Discussion 10 07-09-2005 11:25
White Paper Discuss: FIRST Sponsorship = Excellent Corporate Strategy Chris Fultz Extra Discussion 0 12-04-2005 20:23
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
White Paper Discuss: Continuous Improvement Process for FIRST Teams Chris Fultz Team Organization 2 05-01-2005 20:52
White Paper Discuss: CopyCat Code v1.1 CD47-Bot Extra Discussion 7 31-03-2003 12:37
