Go to Post CD is a forum provided by a group of people. You use it with their permission. Don't like it? Don't use it. - Andrew Schreiber [more]
Unread 10-01-2006, 21:59
David Guzman's Avatar
AKA: Dave
FRC #1251 (The Techtigers)
pic: TechTigers shooting prototype
Team 1251 The Techtigers
Unread 10-01-2006, 22:00
AKA: Dave
Re: pic: TechTigers shooting prototype
Video can be found here:
http://www.badongo.com/vid.php?file=...56.MPG&s=black
Unread 10-01-2006, 22:23
REVving up for a new season
FRC #2848 (All-sparks)
the link appears to be broken...but i really want to see it
Greg Needel│www.robogreg.com
Unread 10-01-2006, 23:15
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I'm also very interested in seeing the video and it appears broken to me, too.
By my estimates, at 500 rpm, you should be shooting at around 1/2 (17fps or so) of the max velocity allowed. Is that what you are seeing?
Team 1257
Unread 10-01-2006, 23:37
AKA: Dave
Yes, the link broke for some reason, but we will be uploading something tomorrow because some one else has the video file and I haven't been able to get a hold of him.
We calculated that the ball was coming out at a little less than half of the allowed speed. Did not go too far.
The wheels are at a 45 degree angle and by the time it had traveled about 6 or 7 feet it was already back to the height of the wheels. I'm not sure how to explain this better.
Dave
Unread 11-01-2006, 08:29
BlazinFire47's Avatar
BlazinFire47 BlazinFire47 is offline
Alumni
AKA: Blaze/Blackmoon/Nova
FRC #0047 (Chief Delphi)
BlazinFire47 is on a distinguished road
Send a message via AIM to BlazinFire47 Send a message via MSN to BlazinFire47 Send a message via Yahoo to BlazinFire47
Dave
by shooting the ball at 500 rpm, you will never achive the length you need. unless you are shooting while parked on an angle on the ramp. if you were to be scoring from a distance of 20+ feet, it would have to at least spin around 6000-9000 rpm depending on the size of your wheel and the motors you use. try a direct drive from the chips and c what you get from them. id step up to a higher rpm motor. by using chain and sprocket you lower the rpms dramatically.
Unread 11-01-2006, 10:42
AKA: Dave
We knew that it was not going to go far enough, we were simply making something quick with the kit transmissions.
Also you do not want to spin those wheels at those RPM you are talking about because the ball will exceed the speed limit.
Edit: The link should be working now. The website that was hosting it was temporally down.
Unread 11-01-2006, 11:15
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
http://www.chiefdelphi.com/forums/sh...ad.php?t=41535
3000 rpm and a 12.5" wheel does the trick, but of course this needs to be refined a lot. We probably don't need it to be 12.5" for starters.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 11-01-2006, 15:47
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
is that tank tread i see
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 11-01-2006, 16:07
just for general knowledge assuming close to complete transfer of speed to the ball you threw that ball about 50 meter/second well over the maximum.
If you you kept the same RPM and used a 3 inch wheel you would be right on the speed limit of 12 meters/second
Unread 11-01-2006, 19:18
AKA: Dave
Yes, this was our 2005 practice robot that we took apart but we left the belts on. This years drive system is surprise
Unread 12-01-2006, 07:23
We're not sure about that. The ball doesn't go that fast based on timing and measurements from the video - it goes about 2X the max speed. The motor doesn't provide much torque at that gear ratio (1:1), so all the energy comes from the rotational momentum of the wheel.
We'll continue to experiment and figure out how large of a wheel we really need both in diameter and weight. I just want to make sure for the benefit of those designing prototypes without the ability to do testing that everyone understands that in this case it's not a matter of motor torque.
www.burobotics.org
pic: Team Fusion's T-Shirt Shooting Robot jdhawg Robot Showcase 72 23-05-2009 23:39
pic: TechTigers at the Races dmellich Extra Discussion 4 20-12-2005 15:55
pic: Shooting a pvc projectile from 70 yards out at Homecoming! falconmaster Extra Discussion 16 25-10-2005 11:05
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
