Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 01-11-2006, 01:01 PM
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Wink Re: 4.3.4.1 - onboard laser?
Ok,
on one hand <G11> says you can't use "alignment devices" taht are NOT part of the robot at the beginning of a match or at any other time....,.Fair enough.
On the other hand, if some sort of "alignment device" is permanently attached to the robot, then that device likely falls under the classification of a "decoration". Yes?
And then, under <R102> and on-board decoration can't affect the outcome of a match and must be in the spirit of "gracious professionalism".
Therefore, Perry Mason...case closed. Just line-up within your 5'x5' box of tape and pray you don't go off inthe wrong direction during autonomous mode; hey which end of the robot faces the wall anyways? Oops....
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
laser pointer 1574aviad Technical Discussion 9 02-20-2005 08:25 PM
Second Annual Laser Quest Lock-in! Gui Cavalcanti Off-Season Events 3 04-29-2004 11:33 PM
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 02-26-2004 03:21 PM
Onboard Camera? XRaVeNX General Forum 18 02-03-2003 08:28 PM
laser guidence for a basic stamp brained valve cover racer Andrew Wyatt Technical Discussion 1 06-05-2002 12:14 AM
