Thread Tools |
Rating:
Display Modes |
Re: pic: Kit Transmission Upgrade kit
Question...
How would one calculate the velocity of the robot when using one large and one small CIM motor given that the 40amp RPM's are nearly identical, yet they are geared 2:1? |
I can't provide a good answer to that, but I can present another question.
If you have the large CIM and the small CIM geared together (at the ratio of your choice) who/what says one will be pulling 40 amps when the other is? I have a feeling this issue is either much more complex than many of us hope, or far more trivial than any of us know. |
Agreed. At 40 amps, it appears that the Large CIM provides nearly 70% more torque. I am no motor expert, and am sure Joe, Paul, Andy or many others could help here.
Guys,
The fact that the torques are different than each other at 40 amps doesn't matter at all. Think of it this way, as Dr. Joe always says: The two motors are combined to act as one motor. The motors force each other to run the same speed. If the motors are matched at free speed, then each motor contributes 0 N-m of torque at the combined gearbox free speed. If the motors are matched at a lower speed than free speed, then the slower motor has the possibility of being overrun by the faster motor and will contribute negative torque (a generator). The faster motor will contribute a positive torque equal to the slower motor's negative torque, thus having 0 torque at free speed. The motors will find equilibrium, but each motor may draw different current values ... who cares? All of this can be calculated from the torque vs. speed and current vs. speed curves. Don't get hung up on the different current draws from each motor. I match free speed ... why? Because it is easy to do, but you can match at any speed you want to. Remember, though, the small CIM has more power (notice I didn't say torque) than the larger one. -Paul |
What happens with RPM? If we were to match the free speed of the large and small CIM motors, how would I determine the RPM to use when calculating the gear reduction to give me the desired robot velocity. I am trying to estimate a true robot velocity but am getting confused with the varying RPM's under load.
Thanks so far though Paul! |
So how much better is it to have a hybred gearbox then a standard gearbox with 2 small CIMs?
I am for one very disappointed with the upgrade part that is "supposed" to allow for the mini bike motor to be linked with the standard cim in the kit. one the instructions call for a 8mm id 3x8" long washer and a 1/4" long washer, both of which where not present in the box when the shipment finally arrived. second the 28-toothed MB gear can barley if any slide down on our mini-bike output shaft. i know this seems to be a little over the edge but to me when you purchase a upgrade for a certain part or object the upgrade should one, be of little ease to install and second have all of the parts that are needed for the completion of the upgrade. i know Andy mark is a good guy, but my team has no time to waste as i well know every FRC team has no time to waste to try to install an upgrade and not have it work. i have purchased his products before and they always have been of high precision and quality, but this current product is by far our worst product. instead of getting the motors installed in a few hours we have wasted two days trying to make parts for a "part" that is supposed to already work and fit on the mini-bike motor. if Andy mark does read this reply then i highly ask and urge him to look over every product that he sends and makes sure that all of the parts are in the box when it is shipped.
to every one else who has already purchased one of these upgrades i hope and wish that you have better luck than we have. |
Andy and Mark are providing FIRST with fantastic, competitively priced products. Just because you buy something from them does not mean that it's going to magically assemble itself and bolt to your robot. Nowhere do they tell you that it will require no work on your own part. In the future, if you think their products are of marginal quality, I suggest you design your own adaptor, and machine it to your own specifications. Perhaps then you'd appreciate the value of their services. |
#10
ahh..this might be random. but nonetheless important.
for the large cim motor, aka: bike motor, are we allowed to take out the gears and the springs that are already attached? b/c we are planning on using the output shaft directly connected to a coupling...and so on... so again...are we allowed to take out the springs and the black gear thing..?? if so..HOW CAN I? i tried to pull it out..it's pretty much impossible. |
#11
Do a search for the thread about removing the pulley. The short answer is you need some sort of gear pulling device, and a heat gun/blowtorch with which to heat up the gear (due to the adhesive used on the shaft). |
#12
It's true that we listed a plastic spacer on our instructions, while sending washers as a replacement. We have changed our documentation being sent with these upgrade kits to reflect this change, as we have received 1 email about this issue also. I apologize that our documentation had this error. The one thing I would like to have better with this kit is the tightness of the "D" holed, 28-tooth gear. These gears are being broached to be a very snug fit on the D shaft of the Mini-Bike motor. If the motor's shaft is marred slightly (by beating on the shaft to get the manufacturers' gear off... or by the manufacturer's gear set screw), then our 28-tooth gear needs to be pressed on firmly. I suggest 2 things to help this situation: 1. Use a scotch-brite pad or a very light sandpaper piece to clean up the Mini-Bike motor shaft before adding on the 28-tooth gear. 2. Heat up the gear to expand its hole before putting it onto the motor shaft. These two steps should help facilitate this installation. I will add these to our documentation also. Andy B. |
| pic: Cyber Blue 234 Teaser 2 | David Hoff | Robot Showcase | 1 | 09-02-2005 15:59 |
| pic: The Kit Arrival | |_-LuIz-_| | Extra Discussion | 2 | 07-02-2005 16:14 |
| pic: S.P.A.M "Littles-C" 12 speed transmission | EricS-Team180 | Extra Discussion | 31 | 27-01-2005 21:20 |
| pic: Team 30 Dual-Motor Transmission | CD47-Bot | Robot Showcase | 27 | 10-02-2004 18:35 |
| pic: TechnoKat Transmission 2003 | CD47-Bot | Robot Showcase | 55 | 23-07-2003 14:41 |
