Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 11-01-2006, 21:25
Engineering Mentor
FRC #0254
Re: pic: Kit Transmission Upgrade kit
What happens with RPM? If we were to match the free speed of the large and small CIM motors, how would I determine the RPM to use when calculating the gear reduction to give me the desired robot velocity. I am trying to estimate a true robot velocity but am getting confused with the varying RPM's under load.
Thanks so far though Paul!
-Travis Covington
Unread 15-01-2006, 21:04
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
The quick answer is to use about 4300 from the smaller Cim, Friction keeps the drive trains from making free speed (5200 approx) the other quick method is to guess that you will make between 75 and 85 percent of the motors free speed if you don't have too much friction in your drive train. As you add parts to the drive line you get less, and you get more friction. Last method it to build it and measure it. Hope this helps
Unread 20-01-2006, 22:45
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
So how much better is it to have a hybred gearbox then a standard gearbox with 2 small CIMs?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 21-01-2006, 13:47
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
Thumbs down Re: pic: Kit Transmission Upgrade kit
I am for one very disappointed with the upgrade part that is "supposed" to allow for the mini bike motor to be linked with the standard cim in the kit. one the instructions call for a 8mm id 3x8" long washer and a 1/4" long washer, both of which where not present in the box when the shipment finally arrived. second the 28-toothed MB gear can barley if any slide down on our mini-bike output shaft. i know this seems to be a little over the edge but to me when you purchase a upgrade for a certain part or object the upgrade should one, be of little ease to install and second have all of the parts that are needed for the completion of the upgrade. i know Andy mark is a good guy, but my team has no time to waste as i well know every FRC team has no time to waste to try to install an upgrade and not have it work. i have purchased his products before and they always have been of high precision and quality, but this current product is by far our worst product. instead of getting the motors installed in a few hours we have wasted two days trying to make parts for a "part" that is supposed to already work and fit on the mini-bike motor. if Andy mark does read this reply then i highly ask and urge him to look over every product that he sends and makes sure that all of the parts are in the box when it is shipped. to every one else who has already purchased one of these upgrades i hope and wish that you have better luck than we have.
Unread 22-01-2006, 01:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you had read the assembly directions before you bought the kit, you would have been able to see that Andy clearly lists the parts you mention as not being provided in the upgrade kit. You should be able to buy some washers and nuts. It's a waste of Andy/Mark's time to go and buy a whole boatload of washers to include in their kits when you can just as easily drive down to OSH/Lowes/Home Depot/any other local hardware store.
Im sorry, but this statement COMPLETELY baffles me. Correct me if I'm wrong, but didn't you buy the upgrade kit so that you wouldn't have to make all these parts yourself? Andy provided you a fantastic service, at a fantastic price, since as you've already said, you don't have the time to waste by making all these pieces yourself. That being said, I'd be a hell of a lot happier to have spent $28 and another what, $2.50 on washers and be able to adapt my motors than to be stuck in a position where I was unable to use the motors due to the belt drive. Any amount of time you spend trying to get the upgrade put together is going to be a whole lot less than if you had to make everything yourself.
Andy and Mark are providing FIRST with fantastic, competitively priced products. Just because you buy something from them does not mean that it's going to magically assemble itself and bolt to your robot. Nowhere do they tell you that it will require no work on your own part. In the future, if you think their products are of marginal quality, I suggest you design your own adaptor, and machine it to your own specifications. Perhaps then you'd appreciate the value of their services.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2006, 19:39
Latergater Latergater is offline
FRC #1047
Latergater is an unknown quantity at this point
ahh..this might be random. but nonetheless important.
for the large cim motor, aka: bike motor, are we allowed to take out the gears and the springs that are already attached? b/c we are planning on using the output shaft directly connected to a coupling...and so on...
so again...are we allowed to take out the springs and the black gear thing..??
if so..HOW CAN I? i tried to pull it out..it's pretty much impossible.
Unread 29-01-2006, 01:27
Cory's Avatar
AKA: Cory McBride
Yes, you can remove them. If you look at the rule about modifying the motors, it allows you to modify the output shaft/mounting points.
Do a search for the thread about removing the pulley. The short answer is you need some sort of gear pulling device, and a heat gun/blowtorch with which to heat up the gear (due to the adhesive used on the shaft).
2001-2004: Team 100
Unread 23-01-2006, 08:41
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
I if Andy mark does read this reply then i highly ask and urge him to look over every product that he sends and makes sure that all of the parts are in the box when it is shipped. to every one else who has already purchased one of these upgrades i hope and wish that you have better luck than we have.
Thanks for the advice.
It's true that we listed a plastic spacer on our instructions, while sending washers as a replacement. We have changed our documentation being sent with these upgrade kits to reflect this change, as we have received 1 email about this issue also. I apologize that our documentation had this error.
The one thing I would like to have better with this kit is the tightness of the "D" holed, 28-tooth gear. These gears are being broached to be a very snug fit on the D shaft of the Mini-Bike motor. If the motor's shaft is marred slightly (by beating on the shaft to get the manufacturers' gear off... or by the manufacturer's gear set screw), then our 28-tooth gear needs to be pressed on firmly.
I suggest 2 things to help this situation:
1. Use a scotch-brite pad or a very light sandpaper piece to clean up the Mini-Bike motor shaft before adding on the 28-tooth gear.
2. Heat up the gear to expand its hole before putting it onto the motor shaft.
These two steps should help facilitate this installation. I will add these to our documentation also.
Andy B.
pic: Cyber Blue 234 Teaser 2 David Hoff Robot Showcase 1 09-02-2005 15:59
pic: The Kit Arrival |_-LuIz-_| Extra Discussion 2 07-02-2005 16:14
pic: S.P.A.M "Littles-C" 12 speed transmission EricS-Team180 Extra Discussion 31 27-01-2005 21:20
pic: Team 30 Dual-Motor Transmission CD47-Bot Robot Showcase 27 10-02-2004 18:35
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
