Re: pic: cathode light assembly
My team actually built a really nice box from some 2x4s and plywood. I'll bring my camera and take pictures tomorrow if I remeber to...
We built ours much the same way, a 2x4 frame, some sheet aluminum on the back, but it just doesn't seem bright enough. We may try lining the inside with foil next.
At first outs was extremely dim, after about 3 minutes it got brighter, then I walked down to the wood shop to get some tools, and when i got back about 10-15 minutes later, it was very bright. I believe that the lights just need to worm up..
Our box took about an hour to make and about 30 minutes to wire. I wired it up to one of our 12v batteries and used a breaker panel from 2 years ago and a 20amp fuse to power it. I was just wondering if anyone else used the correct offset for the lights from the diffuser panel? Also, ours was plenty bright with just wood, has anyone compared a wood box to the official boxes to see how the light compares? |
we used aluminum and a 12v battery and it was bright almost instantly
. i dont think they have to warm up. |
cold cathodes do need to warm up for maximum light output.
4 hours of work? i can understand taking your time, but you had nothing better to do?
| ProE Assembly Editing | daramana | Inventor | 5 | 31-01-2005 13:21 |
| pic: Swerve Assembly | CD47-Bot | Extra Discussion | 3 | 23-01-2004 20:02 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
