Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 14-01-2006, 09:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Re: pic: cathode light assembly
We built ours much the same way, a 2x4 frame, some sheet aluminum on the back, but it just doesn't seem bright enough. We may try lining the inside with foil next.
Work Hard, Have Fun, Make a Difference!
Unread 14-01-2006, 23:08
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
At first outs was extremely dim, after about 3 minutes it got brighter, then I walked down to the wood shop to get some tools, and when i got back about 10-15 minutes later, it was very bright. I believe that the lights just need to worm up..
Our box took about an hour to make and about 30 minutes to wire. I wired it up to one of our 12v batteries and used a breaker panel from 2 years ago and a 20amp fuse to power it.
I was just wondering if anyone else used the correct offset for the lights from the diffuser panel?
Also, ours was plenty bright with just wood, has anyone compared a wood box to the official boxes to see how the light compares?
Elknise
Issaquah Robotics
Unread 15-01-2006, 09:27
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
we used aluminum and a 12v battery and it was bright almost instantly . i dont think they have to warm up.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 15-01-2006, 12:13
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
cold cathodes do need to warm up for maximum light output.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 29-01-2006, 19:27
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
4 hours of work? i can understand taking your time, but you had nothing better to do?
ProE Assembly Editing daramana Inventor 5 31-01-2005 13:21
pic: Swerve Assembly CD47-Bot Extra Discussion 3 23-01-2004 20:02
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
