Go to Post When you start thinking of FIRST as a robotic building contest you have left the pavement and you are in deep weeds. - KenWittlief [more]
Unread 14-01-2006, 23:25
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
Re: pic: 1251 Prototype v 1.2
Originally Posted by tkwetzel
Well...I finally made it back to Chief Delphi after being away for so long.
The sprocket size should not matter at all to answer their question. They asked how fast the wheels were spinning, not the motors. With an angle and distance you need the size of the wheels and possibly height of the arc of travel to find the rpm of the wheels to launch one of the foam balls that far.
Without calculations I will guess that the wheels are spinning at 1,900 rpm.
You couldnt find out the rotational speed from just projectile distance, becausethis would require the assumption that 100% of the wheels energy is translated into the ball (a horrible assumption).
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
pic: TechTigers shooting prototype David Guzman Extra Discussion 11 12-01-2006 07:23
Segway Prototype Components For Sale MattK Chit-Chat 5 15-02-2005 16:34
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
