Go to Post FIRST, an american revolution. - paulcd2000 [more]
Unread 15-01-2006, 12:19
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Re: pic: 1251 Prototype v 1.2
Originally Posted by tkwetzel
That is not true. You could assume whatever efficiency of energy translation you want, but whatever number you use would be an estimate without knowing other information. You also have to estimate a few otehr numbers. But tehy gave you the angle and distance traveled.
You could, but the easiest assumption to use is the motor/tranny speed to the wheels. Problem with using the ball's throw is that you must estimate he distance, then the power transmission efficiency, then backsolve for RPM. Lots of error, though either way. it's hard to guess.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
pic: TechTigers shooting prototype David Guzman Extra Discussion 11 12-01-2006 07:23
Segway Prototype Components For Sale MattK Chit-Chat 5 15-02-2005 16:34
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
