Go to Post overly agressive play, sudden torque gains, and signs of robot acne will cause immediate suspicion, and may be used as justification for a complete tear-down inspection - dlavery [more]
Unread 19-01-2006, 00:30
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Re: pic: camera locked on light 143ft away!!!
Originally Posted by KenWittlief
the two lights are a fixed distance apart. Thats one side of the triangle. If you can measure the distance to both of them you have defined the lengths of all three sides, so you know where you are on the field
or knowing the angle to both lights will determine your position on one side of the field.
I'm no expert, but it seems to me that with only two points, there would be two possible positions you could be in on the field, and it would be impossible for you to determine which one you were in without another reference.
I have attached an image attempting to demonstrate this, someone tell me where I am wrong.
Name:	robot position.JPG
Oh, maybe I shouldn't have pushed that...
pic: Green Light Dermot_135 Extra Discussion 17 19-01-2006 18:02
pic: 1501 2005 Camera Mount Chris_Elston Extra Discussion 5 03-01-2006 21:22
pic: Team 836 CMU Camera Bcahn836 Robot Showcase 2 12-02-2005 22:02
pic: 1351 camera mount sciguy125 Robot Showcase 6 05-02-2005 09:11
pic: Dave demonstrates how IR sensors can be used to call robots to light beacon CD47-Bot Extra Discussion 5 10-04-2004 19:44
