Go to Post I'm a drive team coach, they don't eat lunch during competition. - Rick [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-01-2006, 13:55
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Beware - transmission output shaft is not 5/8"!
You cannot just slip a standard 5/8" sprocket on the transmission output shaft. This shaft is metric, with a diameter of 16mm, or 0.63", NOT 0.625".
You will need either to turn the shaft down to a smaller diameter on a lathe, or drill out your sprocket to 16mm with a metric drill. This year and last year we turned the shaft down.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 18-01-2006, 14:02
Andy A. Andy A. is offline
Getting old
FRC #0095
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Re: Beware - transmission output shaft is not 5/8"!
This came up last year as well. Everyone just took a quick look at the shaft with a pair of calipers and assumed it to be 5/8ths. Then we all had to figure out why we couldn't get any sprockets to go on.
I think most teams just ream out the sprockets, and call it even. It's a pain, but hopefully teams learned a lesson and took the time to look at the drawings this year.
Thanks for the reminder though, I had completely forgotten.
Unread 19-01-2006, 12:26
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
All I can say is WHY?!?
Why give teams a great transmission and make a drive system easier for teams to get up and running, but then make in necessary that teams turn down a shaft (a keyed shaft for that matter!) or ream out sprocketts simply to change the output sprocket?
WHY?!?
Does anyone know of a source of various 16 mm bore 35 pitch sprocketts with a standard keyway?
Perhaps I am a bit frustrated because a great deal of our work time goes into making non-standard parts work together. For teams with limited machining ability, this is a real issue. Yes, I know. It has always been an issue, but with the Kit Chassis, Kit Transmission, etc. FIRST has moved a great deal towards making things easier, but a 16 mm output shaft on the transmission seems to be like "Two steps forward, one step back".
(This whole thing was not an issue for us last year, because we made our own shafts that fit the Kit Transmission. I'm speaking for those teams who have limited machining opportunities - like us this year - we lost our shop!)
-Mr. Van
Coach, 599
Unread 19-01-2006, 14:24
Ken358 Ken358 is offline
Ken358 has a spectacular aura aboutKen358 has a spectacular aura aboutKen358 has a spectacular aura about
Yea its a bit of a hassel. Just ream out the sprokets. I think this is the easiest approch. However, You may have to cut the keyway a bit deeper to get the key to fit after reaming.
Ken
Unread 19-01-2006, 14:38
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
Mentor / Bayou & CMP Division LRI
FRC #0456 (Siege Robotics)
ChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond reputeChuckDickerson has a reputation beyond repute
Consider it part of the challenge. Sure it would be easier if they were 5/8" but part of the challenge of FRC is to work with what you have in the time your given. This is just another one of those real world simulations. Consider that in the rest of the world 16mm may be more common than our 5/8". Maybe this is a hint from FIRST to start moving toward the global metric standard. It is a bit odd though to have a 16mm bore on a 3/8" (#35) chain sprocket.
Unread 19-01-2006, 15:18
artdutra04's Avatar
VEX Robotics Engineer
WHY?!?
Why metric? Why not?!?
There are only three countries in the world that haven't changed over to the metric system - Liberia, Burma, and the United States. Using metric is not backwards, but rather the correct way to do things nowadays. We silly backwards Americans still cannot get that through our heads.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2006, 15:54
Getting old
FRC #0095
Also, I believe that the answer given by the transmission designers was that the output shaft was 16mm because it was the most cost effective method, while still giving teams the option of using 5/8ths sprockets with relatively little effort.
Reaming out sprockets is fairly easy. If you can not do this, then consider turning down the output shaft either by cutting on lathe or by turning it and liberal use of sandpaper. None of the methods of using 5/8ths hardware is ideal, so you should consider buying sprockets from IFI through their website. You are stuck with 21 teeth from IFI. Another option is to look around and find a 16mm sprocket supply. They are out there.
-Andy A.
Unread 19-01-2006, 16:26
Here's the deal. FIRST is not a "buy it and build it robot kit" competition. If you can't be resourceful enough to at the least make do with what they give you, there is no way you will survive in coming up with your own designs. I can't believe that FIRST is so generous as to provide such a great gearbox, and some of you still complain and find every little thing wrong with it. If you don't like it, make your own. But let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for.
Back in the day, we never had beautifully machined pieces included in the kit of parts. Hex broached gears. Cast housings. We didn't even have CIM motors.
Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs.
Unread 19-01-2006, 16:40
Originally Posted by sanddrag
Here's the deal. FIRST is not a "buy it and build it kit robot" competition. If you can't be resourceful enough to at the least make do with what they give you, there is no way you will survive in coming up with your own designs. I can't believe that FIRST is so generous as to provide such a great gearbox, and some of you still complain and find every little thing wrong with it. If you don't like it, make your own. But let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for.
Back in the day, we never had beautifully machined pieces included in the kit of parts. Hexed broached gears. Cast housings. We didn't even have CIM motors.
I agree 1000%!
Unread 19-01-2006, 17:19
Gdeaver Gdeaver is online now
FRC #1640
A dremel tool with a sanding cylinder and 10 minutes will make a standard 21 tooth 5/8" bore sprocket fit. A 9th grade girl team member did ours last night.
Unread 19-01-2006, 17:39
None #0612
We decided to turn down the shaft, as that then gives us the ability to change sprockets easily, should we want a different gear ratio.
Unread 19-01-2006, 20:19
Getting old
FRC #0095
... But let's not complain when we are getting magnificent items in the kit that teams just a few years ago could only wish for.
AND we had to walk uphill both ways to get to our shops!
And we likesed it that way!
trying to keep it light hearted,
-Andy A.
Unread 19-01-2006, 21:27
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
someone should make this a sticky at least for years with the transmission....it will save a lot of people time and anguish
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 19-01-2006, 21:31
#0599 (Robo-Dox)
I am very grateful for the increadible advances that have come along to help teams. As one who has been there (since 2000) and walked uphill both ways, I know what you are talking about.
In those days, many, many robots barely moved - so great were the challenges in getting the drill motors mounted and coupled to a drive shaft and delivering power to the drive wheels. Now, rookie teams are able to build very compettive robots even if they have limited machining capabilities. Do keep in mind that there are teams out there who are trying to be competitive with nothing more than hand tools or perhaps a wood-shop band saw and drill press.
Thank you to those who suggested practical ways for us to use standard sprocketts - we'll probably try the dremel... that sounds pretty easy - we could do that.
Thanks!
-Mr. Van
Coach, 599
Unread 19-01-2006, 21:56
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Stick it in a drill or drill press(if available) and use sand paper on that, then it is an easy 5 minute project.
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
