Go to Post We are all on a big team named FIRST - Al Skierkiewicz [more]
Unread 22-01-2006, 01:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Kit Transmission Upgrade kit
Originally Posted by ICE MAN
I am for one very disappointed with the upgrade part that is "supposed" to allow for the mini bike motor to be linked with the standard cim in the kit. one the instructions call for a 8mm id 3x8" long washer and a 1/4" long washer, both of which where not present in the box when the shipment finally arrived. second the 28-toothed MB gear can barley if any slide down on our mini-bike output shaft. i know this seems to be a little over the edge but to me when you purchase a upgrade for a certain part or object the upgrade should one, be of little ease to install and second have all of the parts that are needed for the completion of the upgrade.
If you had read the assembly directions before you bought the kit, you would have been able to see that Andy clearly lists the parts you mention as not being provided in the upgrade kit. You should be able to buy some washers and nuts. It's a waste of Andy/Mark's time to go and buy a whole boatload of washers to include in their kits when you can just as easily drive down to OSH/Lowes/Home Depot/any other local hardware store.
i know Andy mark is a good guy, but my team has no time to waste as i well know every FRC team has no time to waste to try to install an upgrade and not have it work. i have purchased his products before and they always have been of high precision and quality, but this current product is by far our worst product. instead of getting the motors installed in a few hours we have wasted two days trying to make parts for a "part" that is supposed to already work and fit on the mini-bike motor. if Andy mark does read this reply then i highly ask and urge him to look over every product that he sends and makes sure that all of the parts are in the box when it is shipped. to every one else who has already purchased one of these upgrades i hope and wish that you have better luck than we have.
Im sorry, but this statement COMPLETELY baffles me. Correct me if I'm wrong, but didn't you buy the upgrade kit so that you wouldn't have to make all these parts yourself? Andy provided you a fantastic service, at a fantastic price, since as you've already said, you don't have the time to waste by making all these pieces yourself. That being said, I'd be a hell of a lot happier to have spent $28 and another what, $2.50 on washers and be able to adapt my motors than to be stuck in a position where I was unable to use the motors due to the belt drive. Any amount of time you spend trying to get the upgrade put together is going to be a whole lot less than if you had to make everything yourself.
Andy and Mark are providing FIRST with fantastic, competitively priced products. Just because you buy something from them does not mean that it's going to magically assemble itself and bolt to your robot. Nowhere do they tell you that it will require no work on your own part. In the future, if you think their products are of marginal quality, I suggest you design your own adaptor, and machine it to your own specifications. Perhaps then you'd appreciate the value of their services.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2006, 19:39
Latergater Latergater is offline
FRC #1047
Latergater is an unknown quantity at this point
ahh..this might be random. but nonetheless important.
for the large cim motor, aka: bike motor, are we allowed to take out the gears and the springs that are already attached? b/c we are planning on using the output shaft directly connected to a coupling...and so on...
so again...are we allowed to take out the springs and the black gear thing..??
if so..HOW CAN I? i tried to pull it out..it's pretty much impossible.
Unread 29-01-2006, 01:27
Cory's Avatar
AKA: Cory McBride
Yes, you can remove them. If you look at the rule about modifying the motors, it allows you to modify the output shaft/mounting points.
Do a search for the thread about removing the pulley. The short answer is you need some sort of gear pulling device, and a heat gun/blowtorch with which to heat up the gear (due to the adhesive used on the shaft).
2001-2004: Team 100
pic: Cyber Blue 234 Teaser 2 David Hoff Robot Showcase 1 09-02-2005 15:59
pic: The Kit Arrival |_-LuIz-_| Extra Discussion 2 07-02-2005 16:14
pic: S.P.A.M "Littles-C" 12 speed transmission EricS-Team180 Extra Discussion 31 27-01-2005 21:20
pic: Team 30 Dual-Motor Transmission CD47-Bot Robot Showcase 27 10-02-2004 18:35
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
