Go to Post (Respecting a decision) != (Agreeing with it) - dtengineering [more]
Unread 24-01-2006, 18:45
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
Re: pic: Poor Man's Omni Wheel
Originally Posted by KenWittlief
What material is used on the white rollers? It looks like nylon. Are you planning to cover the rollers with some friction material?
Ideally they would have excellent friction (grip) in the wheel rotation direction, and roll freely sidesways.
Actually tbmantia's link (http://omniwheel.com/transwheel/transwheel-4000.htm) has the exact same rollers we are using. They are the synthetic rubber coated polypropylene roller. Excellent rigidity at the core with a very "grippy" surface. We have yet to test them to their full limit but are confident they will work out well even if they need to be swapped out periodically. Ease of maintenance and low cost make replacing them as they wear a relative non-issue.
One of the other positive characteristics of the barrel rollers is their football shape. This makes rolling a lot less bumpy and makes for more solid contact on and between rollers.
One other spec I failed to mention - they are 6" diameter wheels to the outside of the barrel rollers.
Stop by our pits in Cleveland, Milwaukee and/or Atlanta to see them up close and get a status report on their effectiveness.
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 24-01-2006, 20:24
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
We have 2 of those mini CNC mills. I always saw them unfit for anything but making keychains and circuit boards. I never considered making plastic parts. Good idea!!
1139 Alumni
Unread 24-01-2006, 22:48
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
We regularly cut 6061 aluminum with our mini CNC mills. Both are Sherline mills modified for educational use (one is a Denford, the other is a Intellitek spectraLIGHT). The trick is to know what the machine limits are, and to use sharp, high quality carbide tooling. Last Saturday I used one to drill the bolt circle patterns for the sprockets on the sides of the timing belt pulleys for our treads.
When they're the only machine shop you have, it's amazing what you will figure out to use them for
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: #1018's omni wheels CD47-Bot Robot Showcase 22 19-02-2004 15:04
pic: 296's Tri-Star Wheel CD47-Bot Robot Showcase 23 16-02-2004 11:27
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
