Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 24-01-2006, 23:21
robotaddict's Avatar
robotaddict robotaddict is offline
FRC #1294 (Screws Loose (hopefully going to be changed soon))
robotaddict is on a distinguished road
Some words from the designer
Well, what this thing is used for is feeding balls from the bottom of the hopper up to the shooting wheel. Sorta like this:
./..........<---adjustable angle firing thingy
|....O_....<---firing wheel
..\__....|
......O...|..<---feeder roller (made out of 3/4" hollow aluminum tube and pool noodles)
Ya, sorta like that. I had planned to have a continuous ramp thingy, but my dad decided to try it without the plywood over the dowels and it worked great. I had also originally intended just one feeder roller, but that didn't get enough height past the base of the hopper so my dad suggested another S bend with 2 more rollers, and it works well. It maintains about an inch of compression on the ball all the way up. The reason it feeds from the bottom is to allow the angle adjuster to rotate around the firing axle without being limited by a gravity feed-tube coming from above or the side. Anyway, I hope this helps your design or gives you a few good chuckles.
"Say, what rhymes with 'run for your lives'?" -Flavor text on one of my favorite MTG cards
"THAT SHOULDN'T BE PHYSICALLY POSSIBLE!!!" -Response to the combo I based on that card
"You might as well put a sign on it that says 'I'm a gigantic nerd'." -My dad
John, head programmer of team 1294 and gigantic nerd.
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
Top 10 seasons in FIRST History Karthik General Forum 6 01-08-2005 23:30
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
pic: Team 25 teaser CD47-Bot Robot Showcase 2 21-02-2004 17:58
