Re: pic: Top Gun Team 1294 Teaser
Originally Posted by Elgin Clock
How many balls can fit in there at one time?
And.. what is driving the balls? Is that foam noodle material I see? (the yellow)
Robotaddict is my son. He designed it and I helped him build it.
The loader holds seven balls internally. He wants to use a sensor (TBD) to pulse the single feeder motor just enough to load one ball to the shooter each time the firing button (TBD) is pressed. Behind the loader will be a narrow (one ball thick) hopper which will hold another 8-10 balls fed by a one-ball-thick scooper across the back of the bot. We are big on one-ball-thick designs since we know that any other configuration would lead easily to ball jams of squishy poof balls.
Making rollers out of thin-walled 3/4-inch aluminum inserted into pool noodles was my contribution to the design. They are ultralight, cheap, and strong enough. The 1/4-inch steel axle pins in the ends are heavier than the whole rest of the roller. We might wrap the noodles with a rubber surface (something like a bicycle innertube slit open and wrapped around it) to improve grip.
Cheap and effective -- two words that should be the FIRST slogan.
