pic: Tunring turret
Re: pic: Tunring turret
Now I NEED to know, what are you using for a bearing for the turret? It looks like a simple Lazy Susan or similar piece, but the pictures don't show enough detail to tell for certain. We are noodling this part out right now as well. Any help or advice would be appreciated.
The one in the picture appears to be similar to the one we got from Home Depot... but you can't fit a ball THROUGH the one from Home Depot, so it didn't make the cut. Jason |
Theres always good old McMaster-Carr, too!
http://www.mcmaster.com/nav/enter.asp?pagenum=1034 http://www.mcmaster.com/nav/enter.asp?pagenum=1035 |
Tom and Jason,
Thank you both soooooooooo much. The links you provided were both perfect!!! I will get one on order, or pick one up from Home Depot or Lowe's, today. McMaster-Carr would ship "within 2 weeks". That is cutting it a little thin for the time line we set for the team this year, so local purchase may be the way to go. Thanks again! |
Our McMaster orders get shipped on the day of order, or the next day if we order late. We've made 4 orders from them this build season, and all have come in very fast. |
A point to consider... We attempted using a lazy susan in a prior year for a turret.
What we found was if there was ANY wobble of the vertical part of the turret the lazy susan would eventually spread a little wider and the ball bearings would fall out. So if you decide to follow that path, make certain, you don't have any wobble of the vertical. Or find a method to keep the two plates close together, so the bears don't fall out. Good Luck!! |
How do balls get in to your robot?
| Using a computer to control the pic | mikesown | Programming | 6 | 13-09-2005 19:13 |
| PIC 18F2431 | Sparks333 | Programming | 9 | 24-08-2005 01:24 |
| Can the pic controller send the data to pc? | sunnyrx7turbo | Control System | 2 | 05-08-2005 13:14 |
