Go to Post Test your code and your assumptions. - ShotgunNinja [more]
Unread 27-01-2006, 15:22
Mark McLeod's Avatar
Mark McLeod Mark McLeod is offline
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
Re: pic: 358 has four eyes!
Originally Posted by Cory
It's just a hunch, but Im going to go out on a limb and guess that human eyes will be much more effective at tracking robots than robots will
Have you seen our shooter video featuring our guide dog?
Not all driver's see equally well.
...what happens when they aren't in front of you?
"What is behind me is not important." Unless it's Chuck Norris in a bad mood of course.
(what movie is that line from?)
Maybe we're simple bird watching enthusiasts.
"Rationality is our distinguishing characteristic - it's what sets us apart from the beasts." - Aristotle
Unread 27-01-2006, 15:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
The joystick -> camera mount is extraordinarly effective. We used it last year to great success.
I suppose you could mount an EDUBot controller and have it run two CMUCams and then pass the values back through analog in's on the big RC...
Still, 4 cameras seems a tad overkill.
Unread 27-01-2006, 16:13
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Duh, you guys are idiots. The obvious reason for having multiple cameras is for Matt's proposed method of vision multiplexing by algorithmic implementations of backwards-compatible and proprietary standards. This method is extremely nimble, with its low risk and high yield. The cameras must work in such a way that they resemble a cluster team of multi-scalable processes. From my statistical analysis, I may ascertain that the 358 robot will cause a paradigm shift in the area of FIRST autonomy.
Duh.
http://www.mikesorrenti.com/
Unread 27-01-2006, 19:53
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Uh oh. Looks like its mounted on a vison tetra panel. That means that it'll distract our cannons... Oh wait, it's a vision tetra panel. It's not like we can see those anyways...
Perhaps it's for triangulation of their location by calculating the angles to the target?
Unread 27-01-2006, 21:27
spamified88's Avatar
spamified88 spamified88 is offline
AKA: Sean
FRC #1257 (Parallel Universe)
spamified88 will become famous soon enoughspamified88 will become famous soon enough
Send a message via AIM to spamified88
Wow, you have 4?! We don't even have one yet!!
Head rule guru, I know everything, or at least I'm supposed to...hehe
PARALLEL
UNIVERSE
Unread 27-01-2006, 21:36
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Obviously, the four cameras will all return their own view on the subject of the illuminated target, where, in the brain, the information is fed into a highly complex social algorithm that allows all four streams to fight simultaneously. So, by the end of the match, hopefully, one will have established dominance of the others, just in time for the buzzer. Sounds great!
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 27-01-2006, 22:55
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I would think you are going to need some sort of co-processor.. there's no way you can have the RC monitoring 4 cameras and still doing other stuff. Co-processor for the camera is the way to go.
Unread 28-01-2006, 12:47
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
We're going to keep color profiles of the primary colors of robots at the events and preselect them to track opposing alliance robots, it's also good for tracking multiple people and gunning them down with Poof balls.
We're working on pattern recognition for black and white stripes.
Matt Krass
Unread 29-01-2006, 19:31
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
if we're ever in the same pit, please stop by and explain to me how you managed to use all of that data in 10 seconds
Unread 31-01-2006, 15:28
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Originally Posted by Dzdconfusd
Replace the potentiometers with servos. Just takes a couple of brackets and a basic shaft.
Dude! You totally stole my idea from last year! http://www.chiefdelphi.com/forums/sh...ad.php?t=33418
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 31-01-2006, 15:32
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Yeah we saw that and did the same thing because it was a nice simple solution. The difference was we got rid of the plastic we didn't need to lighten it up.
Unread 31-01-2006, 15:34
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
And it seems like the 4 cameras might just be an extremely inefficient method of attaining hardware fault protection. In this way 3 cameras can be annihilated with poof balls before the robot is blind. Of course a simple protective cage with a window would work equally well, but if you're under budget why not go for the gusto?
Unread 31-01-2006, 15:35
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Yeah, I was going to just rip out the actual movement mechanism in the joystick, but we ended up not even using the camera (not enough time to code + impossibility of using our robot to cap without human intervention)
Unread 01-02-2006, 15:03
Revolverx7's Avatar
Revolverx7 Revolverx7 is offline
Ninja
AKA: Sanders
Revolverx7 is on a distinguished road
Send a message via AIM to Revolverx7
Auto turret targeting. I keep telling them i dont want to have to aim this thing i just wanna drive around pullin 360's so the camera's get to target and do all the work for me.
i wish.
2006 SBPLI Regional Champions (with 271 & 870)
2006 UTC Finalist (with 181 & 585)
2005 SPBLI Regional Chairmans Award
2005 SBPLI Regional Champions
2005 Philly Regional Finalists
Unread 01-02-2006, 15:24
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
i wish.
That doesn't explain why you need 4. Turret tracking can be effectively accomplished with a single camera.
pic: #383 Brazilian Buddy VI - Pic 1 Manoel Robot Showcase 2 07-03-2005 23:03
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: Tigertrons 222 05 Pic #2 team222badbrad Robot Showcase 4 01-03-2005 08:25
