Go to Post There's so much to say about a sponsor who gets involved and cares about your team over one who just signs a check. - galewind [more]
Unread 28-01-2006, 19:39
Latergater Latergater is offline
FRC #1047
Latergater is an unknown quantity at this point
Re: pic: Kit Transmission Upgrade kit
ahh..this might be random. but nonetheless important.
for the large cim motor, aka: bike motor, are we allowed to take out the gears and the springs that are already attached? b/c we are planning on using the output shaft directly connected to a coupling...and so on...
so again...are we allowed to take out the springs and the black gear thing..??
if so..HOW CAN I? i tried to pull it out..it's pretty much impossible.
Unread 29-01-2006, 01:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Yes, you can remove them. If you look at the rule about modifying the motors, it allows you to modify the output shaft/mounting points.
Do a search for the thread about removing the pulley. The short answer is you need some sort of gear pulling device, and a heat gun/blowtorch with which to heat up the gear (due to the adhesive used on the shaft).
2001-2004: Team 100
2006-Present: Team 254
pic: Cyber Blue 234 Teaser 2 David Hoff Robot Showcase 1 09-02-2005 15:59
pic: The Kit Arrival |_-LuIz-_| Extra Discussion 2 07-02-2005 16:14
pic: S.P.A.M "Littles-C" 12 speed transmission EricS-Team180 Extra Discussion 31 27-01-2005 21:20
pic: Team 30 Dual-Motor Transmission CD47-Bot Robot Showcase 27 10-02-2004 18:35
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
